I have had people tell me that it is not possible to weld brass with Gas but saying its not possible to weld aluminium with gas is taking the biscuit David
#13
The guy behind the counter was new so I have to give him some slack. The normal guy I speak with has been out for a couple weeks.
I'll update my profile. |
#14
Chris, I am sure the flux from henrob Jim will be fine but if you want to buy some Anti-Borax flux try www.panel-craft.com
I am sure you will enjoy speaking to Joe Stafford too.
#15
Gas welding
After watching the dvd by David Gardiner I will be using gas cost of a tig unit is a couple of thousand dollars i have a mig and have experienced the cracking on the welds his method of welding is simple and straight forward what i like is that he gives you different ways of tackling jobs and best of all the skills to finish the job to a professional level and you dont need to spend alot of money with fancy tools that is the major difference i have found looking at other dvds on the market unless you have an unlimited cheque book which i havent i would highly recommend Davids dvd already my panel beating skills have improved immensely in a very short time i even have made up my own tools and have already done a paid rust repair job which more than covered the dvd in my books the best money i ever spent i am grateful that he shared his expertise for people interested in learning like myself.brentnz
#17
Mig weld
hello guys
I have not had much of an issue with mig welds cracking . Usually I go through the process at a slow pace . I,m not saying I,m abetter welder than most. Following Jharals directions should keep your problems to a minumum . Thanks larry |
#18
Johnny's method of doing sheet metal with a mig is very correct. A lot of the part time people are only going to have one welder and because the mig is even cheaper than the torch he will be buying the Mig. If you practice Johnny's method you can do as good of work with it as the torch or the tig. You can even get fatser than the one hour per foot. If you properly grind the proud weld level with the sheet metal you will .have no problem wih weld cracking. It is all practice practice practice. For any one that plans on doing a lot of sheet metal seam welding you shoild step up and get either a gas torch or a tig welder as either one with practice will get you through the process easier and faster. For the people with a small budget the torch would be the best option as it is reasonable and very versatile ad does a good job . The Tig is a nice machine but like the othe 2 it takes practice and uderstanding of the weld procedures that you are doing. If You really work at it and practice and kepp your self educated on its use you can getas good as the Rod withDoc and weld a whole panel in less than a minute and get minamull distortion. It is all education,practice Dutch
Dutch Comstock 926 Shells Bush Road East Herkimer,N.Y. 13350 (315)866-3034 comstockmetalshaping.com |
#19
Thanks Dutch. I learned the method from reading on these forums. I was amazed that by following the directions that were given to me, resulted in something that I was pleased with.
I had to weld with the mig because it was all that I had. I have since bought a tig and just got my first torch set. Lately I have been tig welding all of my panels but I still have a lot to learn. I still get decent results with the tig but I think it is because I learned with the mig how the metal would react when welded and what needed to be done to counter react it. Understanding how to work out the distortion is what is important. I'm glad I started with a mig, it is easy to learn and by re-stretching the haz as I went along gave me a understanding on what was really going on. Still have a lot of practicing to do. Probably to late for me but I will pass this down to my son. Same as my Dad passed me down his knowledge.
