Old 12-22-2016, 12:17 PM
Stretch Stretch is offline
Default My Eames Inspired Elephant Project
Hi folks! I've always admired the 1940's Eames designed elephant and have one for my daughter. However, I can't help but look at poor little Nellie and think she looks a little emaciated and needs fattening up! So, I thought I'd make one out of 0.080" aluminium and give it some shape... Well, here's my project in pictures with a little bit of text for info. Hope you like the finished item!
[IMG]http://i6.photobucket.com/albums/y219/15window/Mobile%20Uploads/5D52966F-5413-428E-BE09-11025DC38269.jpg~original
.jpg~original[/IMG]
Matt Keene
www.air-Kraft.com
Old 12-22-2016, 12:21 PM
So, I took Nellie and removed the head. I then wrapped pattering paper around her and took a fairly accurate pattern...
I then laid out the patterns and drew the shape onto 0.080" aluminium:
Matt Keene
www.air-Kraft.com
Old 12-22-2016, 12:25 PM
From there it was a case of cutting out the blank on the bandsaw...
The blank filed smooth and deburred:
Matt Keene
www.air-Kraft.com
Old 12-22-2016, 12:28 PM
Starting with the shape, I used a urethane upper die over a mild radius lower die and created the shape for the ears:
I then shrunk over the crown of the head:
And planished out the undulations:
Matt Keene
www.air-Kraft.com
Old 12-22-2016, 12:30 PM
To create the shape in the face and trunk I beat in a few walnuts over a sandbag with a bossing mallet:
And then smoothed out the walnuts on the wheel:
Matt Keene
www.air-Kraft.com
Old 12-22-2016, 12:34 PM
Similarly, for the main body I again took a pattern and drew out two blanks for the sides and wheeled in some shape:
Matt Keene
www.air-Kraft.com
Old 12-22-2016, 12:36 PM
The upper parts of the body needed shrinking over to where they would meet the upper torso. This was done in the Pullmax with a urethane upper die and radiused steel lower:
Matt Keene
www.air-Kraft.com
Old 12-22-2016, 12:37 PM
The upper torso was created by shaping (blocking) with a bossing mallet and then wheeling smooth:
Matt Keene
www.air-Kraft.com
Old 12-22-2016, 12:39 PM
With the upper torso and the two sides shaped, it was time to fine tune them and tack them together:
Matt Keene
www.air-Kraft.com
Old 12-22-2016, 12:40 PM
I love it Matt. Thanks for taking the time to post the build process.
