Old 12-14-2014, 08:52 AM
The box was planned to be only as long as the underside would be flat, which was to the front and rear edges of the respective wheel openings. Slightly narrower than modified body lines, I used easy dimensions. The box is 36"wide x20"tall. 0124131233.jpg
0419131736a.jpg At each end of the box I have full width rib laid out in the same manner as shorter ribs. These full ribs make these areas obviously inline and serve as datum for the all other ribs. Smaller boxes serve to take up space on the ends of main box. Everything is checked and verified square.
Old 12-14-2014, 09:25 AM
Small spacer/ locater blocks were cut from cutoff scrap and screwed into the box at an angle, which draws tight against the individual ribs enough to hold them secure but temporarily. When all ribs were cut I tried to determine logical locations for outer spacer blocks to aid in clamping and the viewing/ lightening openings.0205131838.jpg
Old 12-14-2014, 10:49 AM
Mike, how did you handle the slope? Is the contact point on each rib the "HIGH" side, which would mean your spacing has to change as the slope changes from positive to negative? Or did you use the same side of each rib and sand away to match the profile?
Old 12-14-2014, 11:13 AM
Kerry, the ribs were cut slighty large about (2mm) in areas where slope is a concern. In those areas I marked the center of the ribs so when I profile sanded them down I could sneak up on the shape.0606131159a.jpg
Old 12-14-2014, 12:20 PM
I found a better picture to show the slope on individual ribs. At least half of the width gets blended.1115131230.jpg
Old 12-15-2014, 10:52 AM
In the last picture, if look at the car on the platform, you can see the laminated foam and the thin layer of clay. That foam is cheap, the clay is about $6/lb. It could have been done with 60lbs, but I used 100lbs because of a mistake.
Old 12-15-2014, 03:08 PM
Here are some pics of the viewing cutouts. These also lightened the buck considerably. I made patterns so the buck would be balanced and slightly self leveling. Some additional holes were adding to assist clamping. 1215141405.jpg
Old 12-15-2014, 03:23 PM
The outer spacer blocks were cut from 2x3x6ft boards purchased at half price from the local home improvement store because boards were badly warped. Blocks were cut so that some were slightly shorter and some longer to correct for varying thickness of the plywood. The blocks were placed to help identify contours and again aid in clamping. 0330131731.jpg
Old 12-15-2014, 03:44 PM
Before the ribs are secured to the big box, the height was set by using a long straight extruded bar. The bar is hung from the full width ribs and adjusted to the intended ground clearance. Now the remaining rib heights are set by measuring from the bar up, simulating measuring from the ground up. 0222131154.jpg
Old 12-15-2014, 07:20 PM
The wheel opening ribs were cut leaving extra 1/2" material towards the tire, to be trimmed later. MDF was used to fill the edge of the fenders. Blocks of MDF were made from 3 layers laminated together, one piece being longer to form a tab to screw to a single rib. 1116131431.jpg
