Go Back   All MetalShaping > Miscellaneous stuff you need to know > Announcements
  #41
Old 03-27-2016, 07:37 AM
RockHillWill's Avatar
Hey, guys. The cast iron legs are a nice touch. would be nice to paint them to match the new wheeling machine.
Imagination is more important than knowledge - Albert Einstein
Click below for ordering or status info on Tommasini Ewheels:
http://www.mantiquesresto.com/RestoredItems/Tommasini/TommasiniWheel.html
Old 03-27-2016, 08:32 AM
MP&C's Avatar
MP&C MP&C is offline
MetalShaper of the month 02-11
Very nice Robert are you going to paint the legs?
Yes, they will get painted, still undecided on color. I prefer something that stands out..
We wanted to get it up and running for a couple pieces that need to be made, and will get some paint on it when we get back to priming..
Old 05-23-2016, 06:11 AM
MP&C's Avatar
I've got a pretty good selection of dies for the bead roller and thought these may come in handy if we could adapt them to the lower anvil cradle on the Wheeling Machine.. I've got a couple dies I use for tipping, and you never know when some other odd shape may help out in a pinch. The Fasti bead roller uses a .94 shaft for the dies, so we started with an oilite bearing, 15/16 outer to 3/4 inner diameter, then a 3/4 outer to 1/2 inner, supported on a piece of 1/2" diameter hardened Stainless..
The two oilites were a tight fit, so they were "pressed" together in the vise..
And to finish it off we have a couple of shaft collars on the way so the die won't walk on us while in use..
Saturday had us performing major shop cleanup so we could better get to an assembly line efficiency in polishing stainless trim and block sanding painted parts. I guess we walked past this one too many times...
....and since the Lennox still had some dies in it from last week....
The outer perimeter will get trimmed a bit more and we'll add a small bead detail on the very edge prior to bolting it on...
Old 05-23-2016, 12:50 PM
Hey, Robert
I really like the louvers and the bead roll idea has a lot of promise. Thanks for sharing.
Old 05-23-2016, 02:16 PM
Paul New Paul New is offline
Originally Posted by KAD View Post
Got some time today to make the stand and get it up and running.
The cast Iron legs worked out great and is very stable with the 24" width (my wood working skills aren't up to "Dan Shady levels" but I think it looks pretty good)
The new upper wheel from Hoosier fit perfectly.
Now to do some testing.
now you just need to build a sheet metal surround for the wood spacer! lol
Old 05-23-2016, 02:19 PM
very nice equipment looks great!
Old 05-23-2016, 03:22 PM
KAD KAD is offline
That "wood spacer" is two inch thick red oak with a hand rubbed finish......it's beautifomous
I went for the "old world charm" look it would be a shame to cover it up
(Dan Shady would be proud of me)
Kirk
Old 05-23-2016, 03:42 PM
Oh yes I missed the fact that you used red oak! Definitely do not cover it up
Old 05-23-2016, 07:43 PM
Onemorehammer Onemorehammer is offline
You out did yourself Kirk, I'll give you am A+, nice looking base and wheel, Dan
Dan Shady
Old 05-24-2016, 01:43 AM
KAD KAD is offline
Wow an A+ from the Woodworking Man himself.........
Many thanks my friend
Kirk
