Old 05-06-2009, 07:08 AM
Default A Hard Buck -- The Hard Way**
This thread was originally posted on the old site. The original thread with photos can be found here:
http://allmetalshaping.forumsdot.com....php?f=15&t=67
Please make all new posts for this thread on the new site...that is HERE. We will be working to get the photos moved over.
Posted: Sun Apr 19, 2009 7:56 pm
Originally Posted by Lewis Gillies
Hi Kerry, Your photos seem to show some pretty big gaps between the fender and the stations on your buck. I'm thinking that a good way to improve on the fit would be to use a bead of the cut and knead epoxy. ...
I agree the distance between stations is pretty big Lewis but that should be all I need to get things to the same arrangement. Between each station is a fair curve. I couldn't do a bondo buck because I had to reverse it...
_________________
http://wheelingmachines.com
Posted: Mon Apr 20, 2009 3:54 pm
Lewis Gillies
Kerry, I agree with you on the distance between stations. I see no problem there. What I was trying to address were the gaps between the edges of the stations and the fender. In your situation I don't see that as a problem ether. I simply wanted to illustrate that if someone found themselves in a similar predicament, there was a way to make Very accurate profiles . It was very late, or early lol when I wrote that. I guess I could have been more concise in the way i approached the subject.
P.S. Kerry, I'm guessing that your first fender has not yet been metal finished, In which case tight fitting profiles would/could cause real problems in making a second none m/finished fender fit the buck. At your meet this year I wanted SO badly (as my contribution) to jump in and metal finish what time would allow. Truth is I just wasn't well enough at the time.
Posted: Tue Apr 21, 2009 8:00 pm
Ok, I was wrong ...partially anyway. Hard bucks are QUITE valuable.
My hand is about .85 now and I'm just dealing with it. Yesterday I tried to fit the previously welded subpanels to the buck and they were not having any of it. There is so much shape and the reverses in the panel make it incredibly stiff and just won't change arrangement. After fighting and thinking evil thoughts for a while I cut them apart at the welds and started over.
Really, REALLY helpful to be able to fit the panels to the buck and weld directly on it.
If you're really sharp eyed, you might see a small crack between the panels...Because I had already trimmed them, they don't fit together and I'll have to make a small panel, probably 2" wide to blend the two panels.
And as I started putting the adjacent panels in place, I was able to manipulate them into arrangement easily:
I'll probably NEVER try to build mirror image panels without a hard buck again. I still want my flexible shape patterns to tell me WHAT to do and WHERE to do it but as for welding everything together, the hard buck is the way to go imo.
_________________
Posted: Wed Apr 22, 2009 8:01 pm
abarthdave
What do you use to cut the wood ?
and what to sand it to get it closer to size ?
I know a bandsaw would be best , but I do not have one ,
but will a bench mount jig saw also work even if its a little slower ?
thanks for the info
Dave
Posted: Wed Apr 22, 2009 8:30 pm
Dave, I cut most everything with a Dewalt saber saw. Some of the smaller sections were done on the bandsaw... a little quicker but not much. A belt sander softens the edges but I didn't worry about it unless it was too jagged for comfort.
Five or 7 ply plywood would be better but this works for what I needed it to do. That is, provide an arrangement to assemble the sub panels into the big fender.
As far as how close it is...give or take a 1/16 or so... closer than I or anyone else will ever be able to see.
_________________
Posted: Wed Apr 22, 2009 9:54 pm
Overkill
I built a form for building the inner structure of a teardrop trailer. Did it in couple steps:
- got the elipse shape I liked from the web and scaled it for my trailer,
- took pic, burned it to a DVD, then stuck it in a friends projection TV,
- bought king sized U Haul mattress box, taped it to garage door, projected image onto it at night,
- used sharpie along with flexible yard sticks to get the shape perfect.
- Transferred the shape to glued up MDF (mind you this thing is 5'x12' with constantly changing radii),
- cut MDF with jig saw - near the line, then
- used 12" disc sander to get it down to the line.
Worked real well. Turned out parts within a 1/16". We bent .065" round and square tubing over it - which serves as the inner frame on my teardrop. I also had cut outs for the vertical and horizontal bars that went in.
Ok, so all this to answer Dave's question. Jig saw to get close, sander to finish up. If you don't have a band saw - you can take the jig saw, cut a grove with it into a piece of plywood. Mount the jig saw to the plywood with some screws, and then turn the whole thing upside down. The blade will be sticking up. To cut a constant curve, just stick a screw at the center, and rotate the piece through the blade. John
Posted: Sat Apr 25, 2009 1:56 pm Kerry Pinkerton
This was the easiest one yet. Fit perfectly without any serious work at all. Took about an hour to weld it in.
I'll clean up the back side of the weld and grind when I get it off the buck.
Old 05-06-2009, 07:11 AM
Default Member responses
Kerry Pinkerton Post subject: Re: Buck the hard way
Hi Kerry, Your photos seem to show some pretty big gaps between the fender and the stations on your buck. I'm thinking that a good way to improve on the fit would be to use a bead of the cut and knead epoxee. ...
_________________
Lewis Gillies Post subject: Re: Buck the hard way
Posts: 6 Kerry, I agree with you on the distance between stations. I see no problem there. What I was trying to address were the gaps between the edges of the stations and the fender. In your situation I don't see that as a problem ether. I simply wanted to illustrate that if someone found themselves in a similar predicament, there was a way to make Very accurate profiles . It was very late, or early lol when I wrote that. I guess I could have been more concise in the way i approached the subject.
Location: Harvest, Al Ok, I was wrong ...partially anyway. Hard bucks are QUITE valuable.
_________________
abarthdave Post subject: Re: Buck the hard way
Posts: 11 What do you use to cut the wood ?
thanks for the info
Dave
Location: Harvest, Al Dave, I cut most everything with a Dewalt saber saw. Some of the smaller sections were done on the bandsaw... a little quicker but not much. A belt sander softens the edges but I didn't worry about it unless it was too jagged for comfort.
_________________
Overkill Post subject: Re: Buck the hard way
Posts: 34 I built a form for building the inner structure of a teardrop trailer. Did it in couple steps:
Location: Harvest, Al This was the easiest one yet. Fit perfectly without any serious work at all. Took about an hour to weld it in.
