Old 04-27-2017, 10:11 AM
Default Trouble-shoot this? (AGW)
For you aluminum gas welding (AGW) folks:
I just got this little problem to solve, and thought to give this audience a shot, for practice.
Diagnose the problem shown here, with this weld:
top
root
Old 04-27-2017, 10:15 AM
Looks like it was the incorrect filler rod for the job as the weld pool appears full of contamination. If it was a TIG weld, you'd think it had been starved of argon as the weld is that dirty.
How many guesses do we get before you reveal the answer?
Gareth Davies
Old 04-27-2017, 10:20 AM
Originally Posted by gareth davies View Post
looks like it was the incorrect filler rod for the job as the weld pool appears full of contamination. If it was a tig weld, you'd think it had been starved of argon as the weld is that dirty.
stee-rike one !!
Old 04-27-2017, 11:22 AM
I don't know the answer, but i think this is a GOOD idea. Could you give us a little more info, what welding process and filler rod? Thanx for the large, clear images.
Tom
Old 04-27-2017, 11:44 AM
longyard longyard is offline
This if fun Kent, and I don't mind looking like a fool.
My guess...bad regulator?
Bill Longyard
Winston-Salem, NC
Old 04-27-2017, 12:53 PM
dwmh dwmh is offline
Kent, good game, with a serious purpose, I'll guess old flux or mixed with contaminated water.
David Hamer
mr.c's Avatar
mr.c mr.c is offline
Oxidizing flame?
Carey Culpepper
TuckPuck® Metal Shaping Tools
www.tuckpuck.com
Old 04-27-2017, 12:54 PM
bobadame bobadame is offline
Looks like the flux is contaminated, or the wrong flux.
Bob
Old 04-27-2017, 01:36 PM
Go on then "dirty gas" acetelyne
Martin
Old 04-27-2017, 01:42 PM
Looks like some of my crappier fast gas welds (usually on old repurposed steel) with too much heat on unclean parts that are too cool to be welded properly and too much filler (because it's easier to melt), with bubbles from the boiling overheated puddle. When the fit-up is not tight,the backside shows a better quality bead than the top, sorta like I achieved ok penetration. But maybe that's not what I'm doing wrong.
Next...
