Wheels for the bead roller.
Wheels for the bead roller. I need to make a wheels for the bead roller. Somebody shawed bead roller or englisch wheel with plastic wheels. It was a great idea, bring me please on the subject, I can not find it. I need to pull the fender end. First try.
Jaroslav |
Jaroslav, we've discussed using plastic wheels for bead rollers, the wheels are from skateboards, and also rubber wheels on English wheels, most often a steel die (wheel) is used opposite a rubber one. On a bead roller, often the plastic one is from a skateboard. Lazze has some video on it here:
https://www.youtube.com/watch?v=iLclPYhIBT4 and here: https://www.youtube.com/watch?v=EU1TG1YDIWQ here's a couple of threads about skate wheels on bead rollers: http://allmetalshaping.com/showthrea...ht=skate+board http://www.allmetalshaping.com/showthread.php?t=5846 http://www.allmetalshaping.com/showthread.php?t=5974 You will find more if you search: skateboard On an English wheel, sometimes a big rubber band is put over a steel wheel, sometimes rubber tires are used. Often the tire is from a gokart. Rubber wheels for English wheels are talked about here: http://allmetalshaping.com/showthrea...t=gokart+wheel You will find more if you search: gokart wheel Over on a different forum they are discussing using a pair of plastic bead roller dies that are 3D printed: http://www.metalmeet.com/forum/showt...light=printing hope this helps
Mark from Illinois Last edited by weldtoride; 11-15-2015 at 09:38 PM. |
I was going to link some of my threads with the skateboard wheel but looks like Mark beat me to it. Thanks Mark!
esentra
I ordered a bunch of stuf ffrom esentra a few years ago and bought an orange wheel. I don't have the part no . they also carry the square hole shafts used for making die holders for a "mini pullmax machine" It was the orange one and is a hard push to use on my HF bead roller. V beld pullies with a 22 mm hole can easily be modified ro custom shapes.
Tim |
I want loking for me this tema.I thought he looked like a machine englisch wheels but it was a bead roller. About a month back there was that tema. It was with white plastic wheel.
I'm do it the rim , send a test. Even the plate sheet metal rast me where after I was out of..... But the result, so far so good. DSC02974.jpg DSC02979.jpg DSC02978.jpg
Jaroslav Last edited by Jaroslav; 11-17-2015 at 12:40 AM. |
Good work you did Jaroslav, glad you found a solution. Vinny
Vinny |
Thank you guys, but I wanted to find the English wheel, or bead roller shaft without bottom with plastic wheels. It is a topic one month back?
Jaroslav |
