Old 08-25-2019, 06:29 PM
Stevemo Stevemo is offline
Default High Lift Pallet Jack or Scissor Table?
When it comes to lifting heavy stuff higher or lowering it down what do you use?
I have two needs for either one of these:
  • Removing 500# table saw from raised shed into a vehicle
  • Removing 115# generator attached to the floor of my Class B RV
The pallet jack has a lower height at rest and at full reach but has a much higher weight capacity. The scissor table can reach much higher.
I am including some links but the brand/cost isn't what I'm trying to research at this point, I'm more interested in usefulness.
https://www.mrdockplate.ca/product/manual-lift-table/
https://www.mrdockplate.ca/product/p...-lbs-capacity/
Opinions and experiences please.
Old 08-25-2019, 08:29 PM
BSG BSG is offline
Donít get the high lift pallet jack!
Once the lift is above a few inches itís stationary, just for raising a pallet for loading and unloading!
I have a lift table, it comes in handy for loading and unloading things from a pickup or a workbench, definitely money well spent!
Kevin.
Old 08-26-2019, 07:23 PM
I'm really conflicted with the minimum lift height of the tables. If I could lift something by hand 15" to get it on the table I could probably lift it into the back of a truck/van.
Perhaps I should have mentioned that I have a 2-ton engine crane which can lift really high:
https://sunextools.com/products/2-ton-engine-crane/
I have a feeling I'm going to try the pallet jack. Using it outside will more than likely require a few sheets of good plywood too.
Old 09-02-2019, 11:47 AM
I have gone a different direction for the time being:
https://www.proeagle.com/collections...el-jack-kratos
This also resolves the difficulty of lifting my van by the frame due to the ground effects kit it has on it.
I can mount a transmission jack plate to it to get the generator down off the van. It won't be stable but I can make it work for the one job.
https://www.princessauto.com/en/deta...ck/A-p8667891e
Old 09-02-2019, 01:05 PM
hot rivet hot rivet is offline
Have you looked at pedestrian stackers? not quite sure if they would fit your needs but better than the high lift pallet jack imo.
Paul
Old 09-03-2019, 06:32 AM
PAToyota PAToyota is offline
I nearly killed (well, maybe just seriously injured) myself with one of those adapters. The real disadvantage is that there is a single pivot point where it attaches to the jack. Unless the trans is perfectly balanced, it's going to want to rotate and roll. Maybe not so much of a problem with a lighter trans, but as they get heavier the danger increases exponentially.
Thomas
Old 11-13-2019, 04:26 PM
john galt john galt is offline
Suggest you look at Northern Tool's 1000lb cap ultra low profile lift table/cart. It has a 36" x 24" flat platform that goes flat to the floor and raises up to 40" high via a foot pedal hydr pump. It has 5" dia & 3" dia polyurethane casters for mobility on hard surfaces. Part # 25621-2053. Currently on sale for $659 plus shpg. Not cheap, but neither is back or hernia surgery. I have no connection to Northern, just trying to provide info to a fellow metalshaper.
