Old 06-30-2017, 03:32 PM
Agronin Agronin is offline
Question Looking for the right technology
Hi!
My name is Shelly.
I'm an industrial designer from Israel and I need your help.
I want to produce attached part (1000 units) from brass or stainless steel. Thickness 0.7-0.8 mm. My problem is that ALL(!) the edges have to be very smooth!!!
What is the best technology to do this?
P.S. I can't use any paint or coating.
Thank you for your answers!
Shelly
Old 06-30-2017, 03:36 PM
Laser cut and then tumble or vibratory finish the parts.
Paul
Old 06-30-2017, 05:04 PM
Originally Posted by Agronin View Post
Hi!
My name is Shelly.
For stainless -
Water jet or Laser cut
Then electro-polish.
Old 06-30-2017, 10:22 PM
For stainless -
I would do as Kent has suggested.
Ezekiel
Old 06-30-2017, 11:58 PM
I third that (waterjet or laser). They may be able to do multiple layers at the same time as it looks like the material would be thin enough to stack and cut.
ærugo nunquam dormit
Old 07-02-2017, 10:42 AM
Default Part's thickness
Thank you for your answer.
Are you sure that the tumble will make my part smooth without damage it? My part is very thick ( less them 1 mm).
Shelly
Old 07-02-2017, 11:50 AM
Default Edm
Wire edm may be cost effective if you stack many parts. I have tumbled parts as small as 1/4 mm thick. Get right media and space the parts so they don't collide. Electro polish is preferred if you can manage it.
Bill Funk
Old 07-02-2017, 01:20 PM
Default What are the advantages of water jet?
For stainless -
What are the advantages of water jet? Will I get a better edges finish than after laser cut? Will it work for 0.8 mm steel/brass?
Thank you
Shelly
Old 07-02-2017, 01:21 PM
Default good idea!
Thank you!
Shelly
Old 07-02-2017, 01:31 PM
Default wire EDM
Thank you again,
I'm not so familiar whit wire EDM technology. What are the advantages? Is it less expensive then laser cut? What about edges finishes?
Tnx
Shelly
