Old 02-10-2017, 09:12 PM
Stevemo Stevemo is offline
Default Making some Hupmobile Bucks
This thread will show me puttering around making bucks for my 1934 417W Hupmobile. I'm working my way up to making some front fender bucks.
I started off with making one for the gas tank as it seemed fairly easy and I wouldn't be out a big piece of plywood if I made a mistake. The materials I am using are 3/4" purebond aspen and 1/4" revolutionary plywood. The aspen is good but the faces are a bit fuzzy. The revolutionary plywood smells funny and dusts quite badly when sanding. I'll have to get a mask as there is quite a bit of sanding involved... If I were to make the gas tank buck again I would start off with splitting the tank and straightening it out. The top half is all sectionalized as I was playing around with my Kreg Jig but that clearly is not necessary and will make it difficult to make the lightening holes when the time comes for that. I also set the buck up so that I can add as much depth to it as I want to up the capacity above the original 15 gallons.
One of the photos in the photobucket album shows the tools I am using. I am actually using someones shop during the evenings so it's mostly just cordless tools and the fold up table. I find the table is a great investment but it's a bit too narrow to support full with pieces of plywood and is also hard to clamp to so I lay some 2x4s across it. This supports the edges of the plywood and allows the use of a square to take positions without the plywood bending and throwing the square out of plumb.
The rear fender is going to have a lot more templates than the gas tank but won't be anywhere near as complex as the front fenders. Heck, I have two NOS rear fenders so I don't even need this buck but it will be good practice. This buck is inspired by Ron Covell's Fender DVD but has a twist. The backbone of my fender has two jogs in it and the fender does not sit flat against the table. I stuck a 3/4" piece of plywood under the fender to take the measurements...hopefully this works out and doesn't end up in lost time. I've taken a lot of measurements and it's now time to make a cut around the outer edge but I want to retain the bottom material on the inside of the wheel arch. This will prove difficult since I want to use this piece as a "master" piece and use it to make patterns.
Any suggestions and comments would be appreciated, especially if I am working myself into a corner. I'm not sure when the metal working will take place, I am not permitted to have an open flame or sparks in this shop.
Cheers, Steve
