Go Back   All MetalShaping > General Metal Shaping Discussion > Tutorials
  #71
Old 03-26-2016, 04:22 PM
Murdoch's Avatar
Murdoch Murdoch is offline
Originally Posted by Jere View Post
Thanks George. I have just recently acquired some rail road box car springs that I will be making some "T" dollies from. I plan on videoing the process and will post it here when complete.
Jere
Sounds bloody awesome. This site needs a like button.
George
Check my Facebook
https://www.facebook.com/george.murdoch.73
Old 03-27-2016, 10:08 AM
It's got "Rate Thread" button, but it's seldom used, not sure why.
Mark from Illinois
Old 05-25-2017, 08:33 PM
Rocket Man 57 Rocket Man 57 is offline
Step one complete. Made a set of forks from an old Ford jack rod. Not the prettiest, but functional.
Step two, try my hand at tucking.
The metal just keeps going back to where it was except for the time it just folded over. For the moment I'm just beating it with a ball peen against a vice or a 4X4 in said vice. I don't have the appropriate plastic head or baseball bat hammer at the moment. I can try that tomorrow. I don't have anything I need to tuck at the moment or any upcoming projects that would require tucking, but it's a skill that I don't have so I want to learn it. I'll be checking the thrift stores and the wife's closet to see if I can come up some scrap leather to make a beater bag for the second part.
Erick
Old 05-25-2017, 10:40 PM
Did you "trap" the tuck first?
And there is a fine line between not enough, and too much, as regards the blows you give the metal. Caught between two metal faces, and too much force, you end up stretching the metal.
Practice.
https://www.youtube.com/watch?v=mkaCJ5gC3jI
CZ
Jerry Roy
Old 05-25-2017, 11:55 PM
I seem to have missed the trap the tuck step. I'll try again over the weekend. I'm not one to get discouraged easily, I will get this. Thanks CaptonZap for the help.
Erick
Old 05-26-2017, 09:34 AM
gashammer gashammer is offline
Something else you may want to try is to put the tucks into the sheet. Then clamp the sheet to a work bench in the shape of the curve you want. Once the sheet is clamped, tap down the tucks. It assists you in keeping the profile you are after.
Mike K
Old 05-26-2017, 10:54 AM
Default Trapping the tuck
There is a hand tool tool for trapping the tuck.
In fact, once the ruffles are made the tool just stomps them down, trapping and stepping down the tuck, out to the edge.
I'll have to get them out and photo a demo.
Old 05-26-2017, 01:30 PM
Mike,
I tried clamping it to the bench. Shot the vice grips across the shop and the tuck spread flat.
Kent,
That tool sounds interesting. I'm always up for a new tool, can't have too many. Some say it's an addiction.
Erick
Old 05-26-2017, 02:10 PM
Kents tool is a hammer.
Greg
Old 05-26-2017, 03:10 PM
Originally Posted by Rocket Man 57 View Post
Kent,
Use cross peen to bang up ruffles into open vise jaws.
Carve out trap stick.
Thump traps closed.
This stick has a simple Vee, but a horseshoe shaped opening is also used.
This method goes back a hundred years ...
