Old 08-06-2014, 01:41 PM
bimmer1980 bimmer1980 is offline
Default harbor freight bender
I also have the harbor freight bender. I didn't want to bolt mine to the floor, so I ended up bolting it to a beefed up pallet. That seemed to work fine.
As with any tool, there is a little bit of a learning curve. Depending on if you are doing double bends, you just have to figure out where to start your bend so you can keep to your desired dimensions.
I think I bent 1-1/2"x3/16 or 1/4" around a 2" die and it seemed to work great. I was surprised at how easily it bent that.... Beyond that, I haven't had much use for it, but it could be handy for future projects....
Brad
Currently working on a new garage for the tools...
Also a member on garagejournal.com
