Old 01-22-2016, 04:02 PM
Moulder Moulder is offline
Default Useful for profile templates?
I've been looking for something to use with my shrinker and stretcher to make profile templates. I have a sheet of 18ga. sheetmetal but I have no way to cut it into strips. I don't really want to use it for that anyways. What about using this as an alternative?
https://www.amazon.com/gp/aw/d/B003D...B1L&ref=plSrch
Would it be stiff enough or flop around too much? Anyone else have any ideas on something to use?
James Sheets.
Old 01-22-2016, 05:00 PM
You can order 1" strips off mcmaster
Old 01-22-2016, 05:06 PM
bobadame bobadame is offline
That's only 4 square feet of material, really pricey for what you want to use it for. Also a bit thin and a bit narrow in my humble opinion.
Bob
Old 01-22-2016, 05:37 PM
22george 22george is offline
Also the galvanizing will come off and get stuck in your shrinker/stretcher jaws. Ask me how l know
Reid A. Van Kirk
Old 01-22-2016, 06:48 PM
I looked at McMasters. I see material in 1/8 and 2mm thicknesses. Isn't that a little on the thick side?
James Sheets.
Old 01-22-2016, 08:23 PM
I was doing a little researching on google and found this video. I thought I would share it.
https://youtu.be/26wGI8hnv4A
James Sheets.
Old 01-22-2016, 08:37 PM
That looks like strapping, (but galvanized, which you don't want) stop by any lumber yard or anywhere they receive palleted goods and it should be a give-away. Larger lumber loads have 3/4" or 1" wide strapping. Strapping is usually a higher carbon content steel, so I don't know how it will shrink/stretch. Have some 3/4" in the back, will give it a try in a couple days and let you know.
Mark from Illinois
Old 01-24-2016, 02:34 AM
Andy L Andy L is offline
I would not use banding. If it says "AAR" on it, definitely not! (American Association of Railroads) it is a specific product with huge tensile strength. The black coating (paint) will clog up your shrinker jaws, and, well you will just be sad. sorry.
I know my "Metalsupermarket" will shear strips like that.
**EDIT** I just looked, there are not any "Metalsupermarket" branches in MO!
My build: www.1932auburnsedan.com
Old 01-25-2016, 08:39 PM
Default Doesn't work well
Originally Posted by weldtoride View Post
That looks like strapping..... Have some 3/4" in the back, will give it a try in a couple days and let you know.
Only tried the stretcher, way too hard, doesn't want to stretch easily, probably not good for tooth life either.
Mark from Illinois
Old 01-26-2016, 11:45 PM
Ok. Thanks for trying it out.
James Sheets.
