Old 03-13-2018, 04:44 PM
mike kleist mike kleist is offline
Default Pullmax Various bits of literature
This lot might be of use to members
mike kleist
Old 03-13-2018, 05:14 PM
Default Some Pullmax P21 questions and information.
I am in the process of rebuilding my Pullmax P21 and I was wondering if any members out there could tell me what the correct endfloat of the variator input shaft should be. Mine is 8 thousands of an inch, with no radial play. Is this within a normal range? There is nothing in the manual for this.
Pullmax P21 variator belt
VX 37X10X1060 OPTIBELT - Variator belt is available from spareto.co.uk £24 but with a one month wait...
Grease
A suitable modern day grease for the Pullmax 21 is apparently Castrol Spheerol EPL-2.
mike kleist
Old 03-14-2018, 02:06 AM
Hi Mike
Lovely machine you have there.
I suspect that that info will be hard to come by, but there is a firm in the US which has taken over the fabrication and distribution (license) of these machines. www.pull-xmachines.com/ They might be able to help with the specs you need.
FWIW, 8 thou sounds nominal to me and don't think you need worry about this - especially as the radial play is sound.
I have P21 manual in PDF if you would need it. You're welcome to PM me.
Manny
Old 03-16-2018, 03:19 PM
Hello
Thank you for the reply. I will email the company and see if they will provide the information.
Regards Mike Kleist
mike kleist
