Old 02-11-2018, 06:29 PM
jhery jhery is offline
Default Fabrication of 7 complete hoods for T57 Bugatti and designing a louvre press
Name:  2-11-18T57hood 014 Large e-mail view.jpg
Name:  2-11-18T57hood 015 Large e-mail view.jpg
Name:  2-11-18T57hood 016 Large e-mail view.jpg
Name:  2-11-18T57hood 017 Large e-mail view.jpg
Name:  2-11-18T57hood 018 Large e-mail view.jpg
Name:  11-30-17bugshop 045 Large e-mail view.jpg
Name:  11-30-17bugshop 046 Large e-mail view.jpg
Name:  11-30-17bugshop 047 Large e-mail view.jpg
Name:  11-30-17bugshop 048 Large e-mail view.jpg
Name:  11-30-17bugshop 049 Large e-mail view.jpg
Name:  11-30-17bugshop 050 Large e-mail view.jpg
Name:  1-9-18T57BobLpress 032 Large e-mail view.jpg
Name:  1-9-18T57BobLpress 033 Large e-mail view.jpg
Name:  1-9-18T57BobLpress 034 Large e-mail view.jpg
Name:  1-9-18T57BobLpress 035 Large e-mail view.jpg
Name:  1-9-18T57BobLpress 036 Large e-mail view.jpg
Name:  1-11-18T57Lpress 001 Large e-mail view.jpg
Name:  1-11-18T57Lpress 002 Large e-mail view.jpg
Name:  1-11-18T57Lpress 003 Large e-mail view.jpg
Name:  1-11-18T57Lpress 005 Large e-mail view.jpg
Name:  1-11-18T57Lpress 004 Large e-mail view.jpg
Name:  1-20-18 001 Large e-mail view.jpg
Name:  1-20-18 002 Large e-mail view.jpg
Name:  1-20-18 003 Large e-mail view.jpg
Name:  1-27-18spinning 001 Large e-mail view.jpg
Name:  1-27-18spinning 002 Large e-mail view.jpg
Name:  1-27-18spinning 003 Large e-mail view.jpg
Name:  1-27-18spinning 004 Large e-mail view.jpg
Name:  1-27-18spinning 005 Large e-mail view.jpg
Name:  2-11-18T57hood 005 Large e-mail view.jpg
Name:  2-11-18T57hood 001 Large e-mail view.jpg
Name:  2-11-18T57hood 002 Large e-mail view.jpg
Name:  2-11-18T57hood 003 Large e-mail view.jpg
Name:  2-11-18T57hood 004 Large e-mail view.jpg
Name:  2-11-18T57hood 006 Large e-mail view.jpg
Name:  2-11-18T57hood 007 Large e-mail view.jpg
Name:  2-11-18T57hood 008 Large e-mail view.jpg
Name:  2-11-18T57hood 009 Large e-mail view.jpg
Size:  68.9 KBI need to fabricate a complete hood for an original T57 I am restoring and also need to build 6 more for the recreations I am building. Will Cronkrite offered to help design and make some drawings for a custom louver press. Each side panel will have 80, 3" louvers in three rows with spaces for hood hardware. They will be 1/4" apart and the rows will be spaced at 3/4. That means there will be 1120 louvers. The original car I am working on was purchased in AU and the photos send to us showed the hood as described above however when the car was delivered by the broker it had a completely different hood which was off and earlier car, so I am building a hood from the photo taken in AU. The side hood panel is 54" long and running three rows with the close spacing means that if they are not accurate the it will look terrible therefore an accurate fencing and registering system would be necessary.
James Hery
Old 02-11-2018, 08:23 PM
Very cool, Jim. This all looks really great.
Old 02-11-2018, 09:03 PM
Top work Jim!
Old 02-11-2018, 11:32 PM
Excellent seeing all the details.
Old 02-12-2018, 02:39 AM
ekdave1962's Avatar
excellent build would love to see a video of it in action
thanks for sharing and the detailed pictures
Geelong victoria
Australia
Old 02-12-2018, 08:43 AM
Hi Jim
Good to see you are still kicking!
Hoods and louvers are looking great!
Thanks for sharing.
Old 02-12-2018, 06:42 PM
onya onya is offline
Very Cool.
Leigh,
Old 02-12-2018, 09:14 PM
Gulley Gulley is offline
Nice machine nice job. Gulley
Old 02-12-2018, 10:03 PM
Mr fixit Mr fixit is offline
Nice machine and awesome work. The only question I have is do you have a pic of the punch to go with the die. I would like to see how you get the nice clean cuts. The one I made distorts the edges a bit and need a little hammer work before that are finished. Not working on a classic like that but still like to learn when ever possible.
TX
Mr fixit
Chris
Old 02-13-2018, 12:24 AM
Default Close-up of dies and top panels
The press is powered by an electric over hydraulic pump from my old frame rack which can run 4 10 ton rams. It has a 5" stroke and has a manual release or automatic release. I use the automatic so when I hear it punch through I just release the button. I have a piece of rubber in the female die to limit the depth of the male die. I am using the top guide from Hoosier Profile English wheel to make the dies fit with a close tolerance. The step in the top of hood to allow the hinge was put in with a Delron die on the Pullmax. After making the paper pattern for the top panel I laid it out on the sheet of aluminum and allowed 1/2" more material at both ends and at the center hinge point. This is partly because one side of the old hood tops is 5/8" longer than the other side. By allowing the center of the hood longer I can cut it to fit once the sides are fitted. The dies for the step on the hood was made in Delron however after running a few practice runs I had to make the bottom die in aluminum so the line would be sharp.Name:  2-11-18T57hood 019 Large e-mail view.jpg
Name:  2-11-18T57hood 021 Large e-mail view.jpg
Name:  2-11-18T57hood 020 Large e-mail view.jpg
Name:  2-11-18T57hood 022 Large e-mail view.jpg
Name:  2-11-18T57hood 023 Large e-mail view.jpg
Name:  2-11-18T57hood 030 Large e-mail view.jpg
Name:  2-11-18T57hood 024 Large e-mail view.jpg
Name:  2-11-18T57hood 025 Large e-mail view.jpg
Name:  2-11-18T57hood 026 Large e-mail view.jpg
Name:  2-11-18T57hood 027 Large e-mail view.jpg
Name:  2-11-18T57hood 028 Large e-mail view.jpg
Name:  2-11-18T57hood 029 Large e-mail view.jpg
Name:  2-11-18T57hood 031 Large e-mail view.jpg
James Hery
