Old 08-12-2014, 05:12 PM
Originally Posted by Frank.de.Kleuver View Post
My new single stage oxi regulator was not stable at 3 psi. I added a second unit so I can set it more accurate since the scale is much smaller. Flame is stable now and if I want more pressure for cutting etc than I can remove the second stage.
Greetings,
Frank
Very good method, Frank. Thank you very much for this great contribution.
Since the acet regs are limited to the 15psi by universal gas safety, there is not much over-pressure on that side.
Old 08-13-2014, 02:11 PM
Moulder Moulder is offline
So I've been looking on the Internet for a secondary low psi regulator but have had little luck. I'm normally pretty good at searching for stuff but this seems to be getting the best of me. I am assuming that it needs to be rated for oxygen, as in a regular compressed air regulator would not work in this application. Everything I have found so far mentions nothing for use with oxygen, not a low enough psi range, or too expensive and defeats the purpose in the first place (I was thinking +/- $100ish range was a good range to be in). Here is all that looks plausible at the moment.
http://portabeer.com/shop/partsandup...-co2-tank.html
https://www.organomation.com/store/a...-gas-regulator
http://www.omega.com/pptst/R44.html
But I'm still thinking none of these are a real option. Anyone know of a regulator that would work?
James Sheets.
Old 08-13-2014, 02:33 PM
Frank.de.Kleuver's Avatar
Hi James,
This is what I know: brand: Gloor
Item name: micro reducing valve type 28
Sorry, it's in Dutch but the relevant terms are there.
The specs says 0-0.7 bar but the unit that you get goes up to 1.2 bar.
I bought it from a specialized welding equipment company. Approx $170 outch.
Greetings,
Frank
Frank de Kleuver
Old 03-14-2015, 03:32 AM
hogdaddy hogdaddy is offline
Here is a nice regulator but a bit on the expensive side.
http://store.cyberweld.com/smoxre2st30s.html
