Old 02-04-2012, 12:10 AM
Bob Bob is offline
And the worst part is the stink stays around a long time. Since I got my mill, I don't sand and grind as often as I used to and I'm liking that. Still use a file a lot though.
Bob
Old 02-04-2012, 10:17 AM
Was going to post this suggestion the other day but got sidetracked, which is easy for me to do. If the phenolic doesn't work out, I have used mahogony wood in the past for hammerforms and cnc work. I had pieces left over from my deck, some 2" thick. Good quality wood is so hard you can not drive a nail into it---had to predrill all the holes in the deck. A relatively inexpensive alternative to try and should be available. Good luck with your project.
George
Old 04-16-2012, 07:31 PM
Be careful when machining G10. The dust is nasty stuff, and not terribly good for the lungs. Not as bad a carbon fiber, but somewhat hazardous nonetheless.
Andrew Slater
HANGAR 18 FABRICATION
Old 04-16-2012, 09:36 PM
bobadame bobadame is offline
You don't want the dust to get into your mill ways either. Use a shop vac right at the cutter.
