Old 09-06-2015, 04:37 AM
Leepac1 Leepac1 is offline
Default Where do I find this
Size:  81.5 KBAttachment 34220
Hi, I am in the process of rebuilding a 1932 Alvis 12/50TJ, as you can see, the radiator cowl has seen better days, I have straightened most of it out but, what I should like to know is, where do I buy the honeycomb insert material from, it will need to be replaced, it is around 5/16" (8mm) deep and can anyone recommend a good chrome plater in the UK? Thanks,
Andrew.
Andrew.
Old 09-06-2015, 04:40 AM
Can't seem to attach more than one photo at a time, ho hum.
Andrew
Andrew.
Old 09-06-2015, 07:09 AM
fabricator fabricator is offline
Default Plating
Originally Posted by Leepac1 View Post
Attachment 34222
Andrew
Hi, I have used this company many times, excellent service.Fairly long lead-times, but worth the wait.
http://www.lpcplating.co.uk/
Good luck,
Fab
Neil
Share what you know, learn what you don't.
Old 09-06-2015, 07:37 AM
neilb's Avatar
neilb neilb is offline
not sure about steel honeycomb but i know you can get aluminium honeycomb, its used in the composites industry.
try this link
http://www.easycomposites.co.uk/Cate...Honeycomb.aspx
I'm not saying this is what you need but...
Neil
Old 09-06-2015, 09:10 AM
jhery jhery is offline
Default honeycomb
Attached is company I have used in UK.
http://www.coolexperts.co.uk/motor-vehicle/recores/
James Hery
Old 09-07-2015, 12:25 PM
Thank you very much Neil, Neil and James, I have looked at sites you have mentioned.
Andrew.
Old 10-09-2015, 11:01 AM
Default A little bit further on
Hi,
I have eventually ended up with a running, rolling chassis (how good the engine is I will find out when it has to do some work, I only ran it briefly).
I have just started on building an Ash frame to support the alloy bodywork, what I should like to ask is...
Can anyone suggest what sort of door to door frame gap should be left (the doors will be 24"x17" front and 18"x17" rear approx), I will be running a "T" aluminium bead around the door edge when finished to act both as a bit of an embellishment and also draught excluder, thanks in advance,
Andrew.
Andrew.
Old 10-09-2015, 02:32 PM
Andrew,
If you haven't sourced the radiator core yet, I found another company on the web.
http://www.vintagecarradiatorcompany...Core-Pattern2/
Phil
Phil
Old 10-10-2015, 10:14 AM
Default Rad honeycomb
Hi Paul,
Thank you very much for that, I have been in touch with a company who list my type of honeycomb, I am just waiting for them to get back to me with a quote,
Andrew.
Andrew.
