#41
I had no idea that there was a smell difference between alloys!
#42
Me neither, you got to have a lot of experience of smelling the different alloys I think, predestinated for a tv show to show this skill
Axel Kloehn |
#43
Nice job! An elegant technique I've used on that sort of repair is to stretch the lumps and bumps into one smooth shape an area at a time then heat-shrink it a little undersize before sculpting it back to height/shape with hammer and dolly. You get exactly the shape you wanted and it stress relieves the part at the same time.
#44
Thanks Will. Thanks Peter. Martin, re-wheeling does smooth the wrinkles but also raises more shape, measurably. I've tried many straightening methods and I use methods that shrink and hold size, so I can stretch to fit if needed. (Like AllyBill does) Marcus, yes it amazes me every time - just like this steel chromed prop spinner I just "un-whacked" - Beech Staggerwing, and it could be polished out it is so smooth (new method). Brent, I heat up and do a 4 inch square because that is what I can control smoothly. And thanks. Hood took me 7.35 hours from wavy to filed out. Scott, Yes it works on .032, .040, .050, and .063. Yes I knock down the highs with hammer, spoon or file handle - whatever is handy before the heat drops. I stay pretty focused on the job until it is done - even the flies can get annealed if they land for too long (cannot see the blue flame envelope). William, thank you. Glad you enjoyed the dissertation. Axel, There comes a time when you can sniff a chocolate and tell what it is. Same for aluminum alloys. Helps to also have squares of them tucked away to compare with ....
#45
My alloys always smell the same, Like burnt paint...................
When it melts all over the floor.
John EK Holden V8 |
#46
What a great thread. I have no sheet aluminum expierence, so this very interesting and very informative. Never entered my mind about smell.
Thanks again for yet another great post.
Keith Daleen Sedalia,Mo. Last edited by keith; 07-19-2015 at 03:11 PM. |
#47
Very nice information and what a great job by both of you!
Thanks for sharing your skills! |
#48
Following this thread closely. Never thought of aluminum smelling differently, will see if I can pick upon that. Thanks for sharing.
BTW, Thank you VERY much for your prompt and nicely done repair to the Mecco torch. I apologize for being tardy in my response.
Will |
#49
Aluminum alloy "sniff testing"
It's not really a "smell" as such, but we use the "scratch and sniff" terminology because you are inspecting a coupon of the material so closely. Highly recommended is having a set of 4X4 coupons of different alloys about .050 thick as comparison. What you have to sniff out: One, the surface reflection for color (silver, bluish, greenish, gray, etc from the Cu, Mg, Mn, Si +++ content). Two, the way it bends with finger/thumb leverage Three, the sound it makes when dropped on a steel plate. Four, heating a corner to see what that looks like just before it melts. Five, heating while bend loading to see where the phase change occurs - you must have an aluminum alloy book handy for this one, and a copy that has all the phase diagrams illustrated so you can see at what temp the metal loses its structural strength (anneals). The ASM four-book set on Aluminum includes one: subtitled "Properties, Physical Metallurgy and Phase Diagrams." ... this is my own personal system of aluminum sniff testing, because I don't yet have one of those nice electronic alloy testing guns .... http://www.scrapmetaljunkie.com/252/...analyzer-gun-2 https://www.bruker.com/products/x-ra...rap-metal.html
#50
But you do have the World's largest collection of rivet guns Kent!
