Old 03-25-2014, 06:49 AM
thefrenchone thefrenchone is offline
Default Side pannel Build for my Citroen pick up.
First sorry about my English
I build a Citroen Ac4 1931 Pick up
I will build a Pick up Bed like a 1934 Ford.
On the Pictures you see the side pannel that i Made with my Dad. Greetings Chrischan
Chrischan
Old 03-25-2014, 07:04 AM
SATAUS SATAUS is offline
Hey Chrischane looks great well done.
Scott
Old 03-25-2014, 07:09 AM
Richard K's Avatar
Looks good. Keep us posted as the work progresses. Thanks for the "how its done" photos
Richard K
Old 03-25-2014, 08:50 AM
Very nice!
Old 03-25-2014, 11:07 AM
Adair Orr Adair Orr is offline
Allright, I've seen this technique around here a bit but as a beginner I would like a description. It looks like a urethane die in the Trumpf bumping the sheet metal directly, and the plywood profile is a guide for the die. What are you bumping against? (in other words, what is below the sheet metal?) Am I seeing oversize corners in the pattern? How did that die hold up and what is it made of?
Any terminology here would be very useful for me. I've seen urethane or rubber dies used in a power hammer to transfer a profiled pattern onto sheet metal in low profile relief. Rubber die on top, sheet metal, pattern, than solid plate below. It turned out very sharp with little or no distortion to the rest of the sheet.
Adair
Old 03-25-2014, 12:27 PM
longyard longyard is offline
Adair,
Here is my video showing Rick Mullin making a Porsche panel using a similar method.
https://www.youtube.com/watch?v=tsL0X4FsEoI
Bill Longyard
Winston-Salem, NC
Old 03-25-2014, 05:24 PM
Hey
the First try that i made was with a Rubber Die(you see on the Picture)
but it was to soft. then i try the Pu Die, it works verry well.
On the other Picture you see whats under the Sheetmetal. 2 Plates of Plywood. bold together with screws. than came the sheet and on top the last plate. its verry importend when you go to the Trumpf/pullmax. you must go deeper and deeper step by step and very slow. Greetings Chrischan
Chrischan
Old 03-25-2014, 05:26 PM
oh i forgott the Pictures
Chrischan
Old 03-25-2014, 05:27 PM
Very nice work Chrischan. Thanks for sharing the work progress.
Old 03-26-2014, 06:22 AM
RatRockx's Avatar
RatRockx RatRockx is offline
MetalShaper of the Month July 2013, Feb 2018
Hi Chrischan, thanks for showing us. I'm about to make a similar panel so this helps a lot .
Is that a Trumpf TAS 42A? If it is I'd like to ask if you have a manual to go with it, I'm still looking for one.
Joris Rockx
www.rockx.net
