Old 02-05-2019, 02:48 PM
Kent_323is's Avatar
Kent_323is Kent_323is is offline
Default Need help on shrinking this edge & smoothing surface
Hey guys,
I could use some help guiding me through some final metal finishing on the roof panel for the All Terrain Track Chair project.
I initially roughed out this part using a wood mallet, and got it decently smooth.
I formed and welded in some light c-channel features to stiffen the flat surface and provide an area to clamp it in position.
The problem is that when I tack welded in those C-channels, it shrunk and caused the overhanging flat flange to be oil-canned. I know it needs to be shrunk to take care of this, but what I've tried so far hasn't worked. Rather than making a mess, I'd like some expert advice!
Additionally, the wood mallet left a lot of small dimples that need to be smoothed out. What's the best way to go about that with basic hand tools?
I also included a few other pics of this project and the other metal shaping I've done on it.
Eastern South Dakota (work & home)
Researching sheetmetal shaping and forming, starting to buy the tools and practice the techniques
My shop projects: www.kustomsbykent.com
Old 02-05-2019, 03:39 PM
Default Hand EW
You can bend the edge or extrude the profile. The edge becomes stronger.
Maybe hand EW will help you. I had a similar situation when this tool helped me a lot. I was use wheels from my big EW.
http://allmetalshaping.com/showthread.php?t=18465
Old 02-05-2019, 08:25 PM
I think if the tack welds cooling caused the metal to shrink . There for I think you need to stretch the welds . one person backing with heavy object another person hitting the welds from opposite side , carefully advancing both on same tack weld .
Old 02-05-2019, 08:39 PM
neilb's Avatar
neilb neilb is offline
yep, if it was fine before welding, it can only be the welds
Neil
Old 02-05-2019, 09:02 PM
Hi,
Neil is correct above, if the panel was correct before the weld, the weld caused the distortion, in the form of a shrink. Stretch the welds only and see. Start out with light weight hits with a hammer and dolly, it can straighten out faster than you might think.
You can look into a hand held pneumatic planish hammer, or possible to build one. Or if you want to do it by hand, use a slapper, instead of a hammer, with a dolly. The slapper hits over a larger surface area and makes it easy to blend out the area.
Hope it helps,
B
Bill Tromblay
Old 02-05-2019, 10:27 PM
Kent_323is's Avatar
Here's some pics of the channels I spot welded in. Not sure there's a good way to hammer the welded spots.
The rest of roof panel is straight and basically how I want it, so I'm not too keen to stretch the portions where I welded in. It's just the rear overhanging lip that is wavy that I'd like to fix.
I do have a torch available, but not sure if that's recommended or not.
Further advice?
Old 02-06-2019, 10:05 AM
geelhoed geelhoed is offline
Meet Hosts
the channel will prevent you from stretching the welds back out. Play a little heat(torch) along the wavy metal to shrink it down. Hand planishing will remove dents and waves. Slapper over dolly.
Andy
Old 02-06-2019, 10:11 AM
Tom Fritz's Avatar
Tom Fritz Tom Fritz is offline
With that much structure in place you will need to shrink the front edge. There are many ways to accomplish this. I have used a very low crown hammer and a leather wrapped dolly. A shrinking disk works well. A torch and small spot shrinking small areas along the edge, this will more than likely over shrink the area but just planish back to shape. Some how hold up a Lancaster type shrinker to do the edge.
Tom Fritz
Customs Classics and Rods
www.ccrod.com
Your 49-51 Ford/Mercury woodie expert
Old 02-06-2019, 10:42 AM
Cpeterson Cpeterson is offline
what gauge of metal did you use?
Craig Peterson
DAGGER TOOLS
http://daggertools.com
Old 02-06-2019, 11:01 AM
Kent_323is's Avatar
If I remember correctly, it is 16 ga steel.
I will give the torch a try.
Can you give more details, step by step of the torch & shrinking method?
Are there any good video links to show this method?
Thanks for all the input so far!
