Old 10-04-2017, 03:30 PM
Originally Posted by Rex_A_Lott View Post
A chef,a sculptor , metalman, and now a clown....
I did have a fellow tell me he liked Ford springs from before the War for repurposing, but he was using them to make hatchets, using blacksmithing techniques. Good Luck
Stop by sometime, Barry. I'll use the springs off of one side and you can have the springs from the other side...
Seriously, I was thinking the same thing as you posted about using older springs so thought I would ask. Lots of stories floating around.
Old 10-10-2017, 12:15 AM
Default Another use for the spring steel slapper
When making difficult off-set bends in the brake, sometimes the 20ga steel needs more help going into place...
The slapper spreads out the force so the dead-blow hammer makes the sheet move with few marks.
When clamping the part down to make another offset, the slapper again spreads out the clamping force, avoiding marks.
Still a ways to go, but a pretty good start on a rocker panel that bows out and curves under at the same time, with added "artwork" coming along next.
Old 10-10-2017, 09:38 AM
Thanks for all the examples and processes.
Old 10-10-2017, 09:59 PM
Default Taking down large high spots - no marks
You are very welcome, Steve.
For large high spots on panels with a fair bit of crown ....
it's nice to be able to move some metal without leaving marks.
Note that the grip is halfway up the hammer handle.
And the slapper is held firmly against the panel.
Swat once and see.
Swat again for more movement. Easy does it.
(car: Alfa Boano, one-off for Turin Auto Show, 1957.
winner 1st in Class, Pebble, 2017.
Work in this photo being done at Fast Cars, SoCal.)
Old 10-10-2017, 10:30 PM
Chris_Hamilton Chris_Hamilton is online now
Thanks Kent as well for taking the time to post this and other stuff on the forum. I appreciate it. I made some leaf spring slappers before I got your booklet "The Forming Stump, Slappers, Spoon and Spike" and was surprised how close the ones I made were to your design. Made me feel like I was on the right path (or at least in the right direction).
Do you have any recommendations on what leaf springs would make good tools. Stuff that is obtainable in junkyards. I found that Ford truck leaf springs seem to be higher quality stuff than Chevy/GMC (later model late 90's early 2000's) Also can I assume the thinner the spring the better quality steel?
Old 10-11-2017, 01:31 PM
Glad to help, Chris. You are very welcome.
I think any auto/truck suspension leaf spring with the right dimensions is the best way to go, however you can find them. Cheap, available, and more metallurgy than you will need for whacking metal.
Now, for smithing out "edged tools" .... that is a whole 'nother (side-trackin') topic.
Old 10-12-2017, 05:08 PM
Default steel slapper leveling the aluminum gas weld
This is the standard grip to have on the steel slapper, (from "metalmen" / craftsmen going back to 1919 - Frank Cufaude, Jim Taylor, Walt Borland, Gene Halvorson ...)
Hand is firm on handle, index finger extended onto back of striking face, for control/accuracy. The slapper will acquire a shiny spot from that steady finger.
Alternate grip, for a different body position - when your body is lower than the panel.
Whackity-bambambam until the HAZ is level, distortion and stress gone, softness back to hard, and weld bead tamed enough for the file.
Thus:
and
etcetera
Old 10-13-2017, 08:41 AM
blue62 blue62 is offline
You always do great write ups.
Thanks I learn something from everything you write.
But my God your collection of photos is amazing.
Thanks for posting some of them.
Dave Bradbury
Old 10-15-2017, 08:10 AM
sblack sblack is offline
In England, "slapper" is a derogatory slang term for a vulgar or immoral woman! So be careful where and how you use the term.
Scott in Montreal
Old 10-15-2017, 10:26 AM
Youre correct, be careful how you use the term!!
However their treatment is the same!!
Tee hee, please remove if inappropriate.
