Old 04-28-2017, 12:55 AM
dschumann dschumann is offline
Default Swapping out welding torches on O/A
So, I own my tanks and a nice little Meco Midget torch and lightweight hoses for welding tubing and sheet metal.
Is there a quicker and easier way to swap torches when I want to use a rosebud, cutting or larger welding torch?
Currently I disconnect the lightweight hose and attach the regular hose to a regular size torch. I'm figuring maybe someone here has a neato idea for doing this quickly and safely.
Thanks!
Drew Schumann
Old 04-28-2017, 06:30 AM
newibiner newibiner is offline
Kent White offers quick disconnects.
Shawn O'Harrow
Old 04-28-2017, 07:48 AM
Thanks Shawn ...
Drew,
http://www.tinmantech.com/products/w...k-connects.php
They can be hooked up in 3 ways - on the regs, in between hoses, at the torch.
Half of the fitting set is also available.
Old 04-28-2017, 08:10 AM
Default Quick connects
I have the big part of the quick connect on one side of Y valves on the regulators. My favorite torch is hard connected to one side of the Y so it is always handy. I then have half dozen other torches with the small part of the quick connect I can swap out. It works good for me.
Bill Funk
Old 04-28-2017, 09:58 AM
Thanks Shawn ...
Drew,
Ah. That looks the treat.
My regular size hose is much longer than I need, so I am thinking I will reduce the size of that hose, and rig a hose to hose to some regular size hose as well as the small hose.
That would keep the hose length down to a manageable size and keep the torch from becoming "clunky".
Am I on the right track?
Drew
Drew Schumann
Old 04-28-2017, 10:15 AM
Drew
As I read into the product more thoroughly, I will need some kind of adapter to go from the regular sized disconnect to the small hose?
Drew
Drew Schumann
Old 04-28-2017, 10:55 AM
Drew
Hi Drew,
Actually our small hoses come to you with the necessary adapters included.
Old 04-29-2017, 03:09 AM
Hi Drew,
So, since they are the small hoses I bought from you, that is how they are currently hooked up to the regular sized lines, duh! I can't believe I didn't figure that out on my own!
So, it looks like I'd just need a full set of quick disconnects and then a 1/2 set for the small hoses.
Cool.
The prices aren't horrible for the convenience.
When I get home and organize my shop, my plan is to rationalize flow and develop systems for everything. QD's and automatic starting for O/A torches are part of that.
Drew Schumann
Old 04-29-2017, 01:04 PM
Cool.
Good to hear, Drew.
I try to work this stuff out so other craftsmen have a decent chance at the first go. The quick disconnects are more useful when you only buy a set and a half - and don't have to toss the other unused half set in the back of a drawer ....
