  #71
Old 04-23-2018, 05:50 AM
Kyle_yocum Kyle_yocum is offline
Looking good buddy!
Kyle
Old 04-23-2018, 09:09 AM
Good stuff Robert !!
Old 04-24-2018, 10:58 PM
MP&C's Avatar
MP&C MP&C is offline
Thanks for the comments guys!
More progress on Biederman hood, the butterfly hinge parts were removed from the old hood, and the piano hinge that attaches the hood sides was removed.
Piano hinge is actually part of original hood, hemmed at the lower edge. Sanding through the hemmed edge releases the hinge..
....and any spot welds were removed by grinding through the hood side to save the hinge..
This tool shown in following video was designed and given to me by Clint Button (Carolina Sculpture Studio) at the recent Redneck Roundup I attended in Rock Hill. Serves multiple purposes in clamping to rules in forming an infinite sized compass to marking offsets as shown. Worked very well to mark the rear edge... Thanks Clint!
https://www.youtube.com/watch?v=cnRl2RsreNA
Clamping and plug welding the butterfly hinges to the hood.
Hood trimmed and gapped.....
https://www.youtube.com/watch?v=DNXVuMiyhPw
....and our next task will be to TIG weld the piano hinges to the trimmed lower edge of the hood, these hinges attach the hood side panels..
Old 04-25-2018, 05:19 PM
Making tracks, Robert.
Great stuff!
Old 04-28-2018, 10:45 PM
MP&C's Avatar
Thanks for checking out the progress Kent!
Progress through today, TIG welding up the hinges onto the new hoods..
Some SPI epoxy is mixed and brushed on, allowing it to seep between the welded parts and seal things up..
As the dominoes continued falling, the hood sides did not fit either. It was our initial plan to cut off the hinge from the top, wire edge from the bottom, and add a new center section, all parts cut to fit properly and welded back together. When we stripped paint off the lower wire edged part, we saw a bit too much pitting, rust, etc. that we opted to change to a full new lower section under the hinge. Nothing to wire edging 16 gauge, right?
So we whipped up a set of dies to add the joggle needed for the external wiring, using 3/16 solid rod for the wiring..
Practice sample:
With that complete, we tipped the lower edge to run through the joggle die..
https://www.youtube.com/watch?v=POa_yIyH3JU
The wiring and inside of the joggle were both degreased, scuffed, and SPI epoxy added prior to folding the remainder..
Vise grips modified so they wouldn't slip off the wiring..
Wiring locked in place with some hammer action...
Hood side is tacked to the hinge, mocked to the hood, and trimmed for gaps
https://www.youtube.com/watch?v=SH2H3nR4AOc
It's not done, but that's all for today, we're packing it up for the car show in Leonardtown tomorrow.
Old 05-03-2018, 10:10 PM
MP&C's Avatar
Tonight we did the wired edge on the Biederman truck's drivers hood side, so we did a couple videos of the process. We did a practice sample to make sure our adjustment on the folded flange length gave us a good wrap with a slight gap for paint..
https://www.youtube.com/watch?v=1b6TiuiUQQQ
This shows the basic process of closing the wrap, wasn't as pretty as it should have been, but hey, this is practice.
https://www.youtube.com/watch?v=MNc9WJ3SmYA
For the hood side, we used the tipping wheel in the Fasti swaging machine (bead roller) to add the flange. After running through the Lennox for adding the joggle, the panel was scrubbed with a warm dish soap and water mix using scotchbrite, then scuffed with 220 paper, then SPI epoxy added in the channel. After our 3/16 wire was laid in place, any remaining bare spots on the wire were also brushed with epoxy. The entire length was then closed as per the practice sample. We'll let that set a day or so and get the recycled hinge welded to the top.
https://www.youtube.com/watch?v=GiNrkZ7pslg
Old 05-05-2018, 09:38 PM
MP&C's Avatar
Finishing up on the Biederman hood fabrications today.. That's what I told myself anyhow...
Getting the OEM hood hinge welded to the new hood side..
Factory version had spot welded angles on the inside to bolt side emblems to, we'll see if we can improve by eliminating a rust trap...
This should do..... Vise mounted jigsaw with optional pony clamp cruise control Don't try this at home..
Beltline trim added.....Hey! it lines up with the cab!
Hood sides added.. and Robert is done with the hood..
Video Version:
https://www.youtube.com/watch?v=KTXzEPYzPxE
Old 05-05-2018, 09:56 PM
pplace's Avatar
pplace pplace is offline
A job well done! Looks and fits perfect.
Dane
Old 05-06-2018, 06:40 PM
Great work on the hood Robert!
Old 05-07-2018, 05:27 AM
Great to see it all line up finally.
