Go Back   All MetalShaping > Miscellaneous stuff you need to know > Posting Pictures
Old 08-04-2013, 07:25 PM
NXCESS NXCESS is offline
Default air box for Chevy pick-up
This air Attachment 22896box was for a customers pick-up
I first built this aluminum frame.
Attachment 22897
This is with the filter
Attachment 22898
The cardboard mockup
Attachment 22899
Tack welded the mounting ring to some stand offs
Attachment 22900
Transfer from the paper pattern, like I learned on this site.
Attachment 22901
After cutting out the roughed in part, I bent it with the wheel and a rubber upper.
Attachment 22902
Did some hand work with a rubber hammer over a old torque tube
Attachment 22903
Bend by hand over an angle iron
Attachment 22904
Trial fit
Attachment 22905
Clamped for welding
Attachment 22906
Welded both sides so I could grind away outside welds
Attachment 22907
After sanding
Attachment 22908
Drilled and tapped for mounting the mass sensor
Installed in pick-up. Next stop - painter
Terry
Old 08-04-2013, 07:27 PM
don't know why the other photos did not come out. Contacted the Administrator for help.
Terry
Old 08-04-2013, 09:06 PM
Trying again
This is the aluminum frame
Terry
Old 08-04-2013, 09:08 PM
With the mounting flange tacked on
The mock-up
Terry
Old 08-04-2013, 09:11 PM
Transferring the pattern
Wheeling the upper
Working it by hand and a rubber hammer over a old torque tube
Terry
Old 08-04-2013, 09:14 PM
Bending a flange by hand over angle
Trial fit
Clamped for welding
Welded both sides so I could grind down the outside welds
Terry
Old 08-04-2013, 09:17 PM
Ground and sanded
Drilled the flange to mount the mass air sensor
Finished and ready for the painter
It was made from 5052 X .060 aluminum
Terry
Old 08-04-2013, 09:43 PM
Terry, nice looking piece, thanks for taking the time to re-post the pictures of the project.
Old 08-12-2013, 05:05 AM
ozi jim's Avatar
ozi jim ozi jim is offline
MetalShaper of the Month August '14
Nice Terry.
I used to do a lot of this stuff.
It is so time consuming getting to all come together.
post 5 the alloy magnets ? I have been looking for them for years.
Jim
Nothing is to hard its just how much time you want to give it.
Old 08-12-2013, 06:57 AM
Richard K's Avatar
Richard K Richard K is offline
Nice fabrication and good looking result. Thanks for photo detailing your process.
Richard K
