#41
How hard is it to sand the brass. It must be time consuming, because it has to be almost perfect on the end result. any deep scratches at the end would kill you
#42
I would buy one also!!!!!!!!!!!!!!!!!!!!!!!!!!!
#43
Very interesting stuff in this thread David.
Have you tried to TIG-weld the brass David? I have seen it done many times, and without pinholes. But the welders are very skilled and have TIG-welded for many years.
Torsten Vig |
#44
Thanks guys.
Johnny the grinding and sanding must be done with care so the metal ends up the same thickness. any file marks can be sanded out (within reason) that is why I make them from thicker than original material. here is the inside of the shell when sanded up David
Metalshaping DVD. www.metalshapingzone.com Metalshaping with hand tools on youtube http://www.youtube.com/watch?v=IGElSHzm0q8 All things are possible. Last edited by David Gardiner; 03-22-2011 at 01:10 PM. |
#45
Torsten, I never had a tig when I started making these. I have not tried tig welding brass. My tig is not working at the moment but I may try it 'cos of the problems I mentioned before. The problem may be that welding the brass may be OK but will it give a weld that can be ground to the thickness of the sheet then beaten without it cracking.
The weld above can be hollowed on a stump to a very high crown without splitting. I will post some photos at some future point. David
#46
Wayne and Rick, I have scheduled in some time for filming my next DVD this summer. I did a little last year but I just had too much other work on and could not find time for it.
#47
That is great news David, put my name down for one as soon as they are ready!! Cheers,
Daniel Gunderson |
#48
Very cool David. I'll order one as soon as it comes out. Do you plan to show some wheeling?
Gert-Jan van der Heiden |
#49
Yes, this one is on using larger tools. I may do one as a follow up to the last with more on hand tools I will have to see how it pans out.
#50
Nice that you showed us how it's done. How thick is the brass, and what alloy?
Makes me want to go try to build one
Ron Lile Captain of an unknown, landlocked pirate ship |
