Alright, between David and John this has really became a thread of interest.
I was taught (sp?) to only replace the metal that needed to be replaced. Small patches, but make sure the rust was completely removed. Usually an inch around the rust after blasting is sufficient. I understand keeping seams next to body lines for strength, but after cutting my arms up for a dozen years, I understand why one would keep the seam out in the open to make it easier to metal finish the weld without fillers. I am subscribing to this thread for sure!!!!
#12
Hi John. I have seen some of Scott Knights work and I can tell you that he puts his joints in exactly the same places as I would when making a body.
I never said that it was not possible to dress out any panel no matter where you put the joint, it obvoiusly is but why make your life hard? Dont cause a load of distortion and you will not have to dress it out. The welding technique I use causes very little distortion and I can metal finish panels very quickly. A big part of the skill involved in making bodies or panels is knowing where to put your joints so that you have least amount of work forming and then finishing the panel to a metal finish that requires no filler. (bondo) A picture speaks a thousand words David
Metalshaping DVD. www.metalshapingzone.com Metalshaping with hand tools on youtube http://www.youtube.com/watch?v=IGElSHzm0q8 All things are possible. Last edited by David Gardiner; 10-21-2009 at 07:42 AM. Reason: Add photo |
#13
Wow! We are getting a lot of information here. Thank you!
Now, the reason for thinking in terms of replacing the complete lower part of the panel. I had taken the doors to my friend's media blasting business to be cleaned. He could be trusted to do an excellent job but on that fateful day he was called away from the business on a family emergency. His newly hired inexperienced teen age helper decided to take it upon himself to media blast the doors. Yikes! He just kept going and going. Now it is like egg shell thin and wavy plus the fine rust holes. He is no longer working there. Peace, Chaz |
#14
Chas do you think you would be able to make the whole doorskin because that would be the best thing to do if the rest of it is as bad as you say.
#15
I put the seam where it is easy to get to. as for where, close to a body line or not, If i cant get to it, I cant dress it well. I'd shoot for the middle of the panel if its easy to get to. I have done a seam high up near the line before, I was cussin like a sailor before I was done. I have found that no mtter the welding process, or where it is, it might distort alot, it might not. Either way, it needs to be adressed, hopefully easily.
Marty
#16
Just a thought, has anyone ever added bracing that could easily be removed at the weld seam? Just tack a few rods between the skin and the shell and knock them loose when your done welding.
Sort of like welding in a fixture but at a much smaller scale.
#17
when heating something in a loacalized zone, and it cools, it wants to shrink.
if you remove the braces, it may look straight, but the stress in the haz may allow it to move. Much easier to work the weld as you go or after you are done. Marty
#18
John, I dont think that Chas has a power hammer or even a hand held planisher. When I teach at college I have to adapt the way I would do things to the skills and tools of my students and I try to do the same thing here. If I were doing this repair as a job I would make a new skin, this would be the only way to achive the standard I work to. If the customer would not pay for this I would not do the job. This is a person who is trying to carry out a decent repair with limited experience and equipment so I am giving advice with this in mind. Once a person has many years of experience and lots of machines almost anything is possible.
#20
David, the same seam John is talking about is easily handled with a hammer and dolly, no machines needed. Just make things a lil faster. Sometimes.
Marty
