Old 03-08-2020, 07:06 PM
ken from Peterborough ken from Peterborough is offline
Default rotay machine or a bead roller?
Hi all, new guy here with a newbie question, if you had to choose one or the other which one would you choose, a bead roller or a rotary machine?
I passed a chance to get one(rotary machine) on sale but thought the shallow throat may be an issue in the future although I don't plan on working on big car panels or anything but somehow thought a bead roller might be more versatile.
Do you own both? or settled for one of the two? I personally would use one for stiffening a sheet of thin copper or Aluminum, roll edges, that's a bout the extend of my use.
Ken
Peterborough, Canada
Old 03-09-2020, 12:27 AM
Hm, I'm no expert but I've seen American "bead rollers" and English "Jennies" and "rotary machines" interchangeably used in shops for decades.
Sometimes the dies even interchange.
What'll it be, a "Wing" or a "fender?"
Body solder or lead work?
Old 03-09-2020, 12:45 AM
I own a rotary, but would imagine that a bead roller would probably cover most eventualities.
Manny
Old 03-09-2020, 09:27 AM
Thanks for the replies so far.
I thought the dies for a rotary machine were different than a bead roller.
Ken
Old 03-09-2020, 10:09 AM
Most of what I think of as Rotary Machines, or Jennys are rather shallow throat. Today, most BEAD ROLLERS have at least a 18" throat.
A sheet metal shop I worked for in my late teens had a whole row of Jennys lined up on a both sides of a narrow bench. Must have been a dozen with various dies.
As Kent said, they do the exact same thing and the names are often used interchangeably.
Old 03-09-2020, 06:34 PM
Thanks Kerry, it all makes sense now, the bead roller I'm looking at and most likely get is an 18" HF type that our Princess Auto sells (Canadian Harbor freight) , it will need some re-enforcing to stiffen it up a bit but I'll see if I could get by without welding anything to it .
Thank you all for your comments/thoughts.
Ken.
Ken
