I bought a set from Ron Covell a few years ago. I'll take a picture when my camera comes home in a couple of days.
#12
tank rolls
#13
mmacmmac what Dies are you wanting? Message me or Call me later today, Peggy's out at the Dr's this a.m. for a bit so we're short handed
i never heard of tank dies, but there is a lot of dies i havent heard of. if those tank dies work out for you, i might be intrested in a set. could they handle 14 ga galvinized?
cory mackenzie |
#14
Dies need to be designed around the Sheet Metal Thickness Generally.
This is Especially true of Tilting Shaft Machines. If Your Machines Moves Wheels Only in the Verticle Direction without Tilting then Depending on the Die almost Any would do. Quote:
Joe Andrews Hoosier Profiles Inc 213 N 1st St Decatur IN, 46733 Phone 260-301-9034 Fax 260-724-2236 |
#15
Thanks for the Pics and Info bob.
I Machined the Stop off of the end of one Die and Played with it a Bit on a junk piece of Material. They Work very well but I need to power my HF Bead Roller. I Suck at electrical so it Looks like I gotta Spend some Time reading here. Someone should Offer a Kit to Power the HF Unit since almost everyone has one.
#16
I'm still trying to figure out what the end result of using these dies is.. Could someone please post a picture of the bead roller actually makeing a part with them?
Thanks!
No longer driving for a living so its time to dust off the old tools and get crackin'! I'm now spending winter in the Northeast and Summer in Texas??! I think I got it backwards again... Bill F. |
#17
It's basically to tip an edge using a round bend instead of a tight 90* fold. Still makes a 90*, but it's a rounded corner.
#18
I have the set that came with my Baileigh machine. I haven't figured out how to do anything but destroy metal with them. I think I need some more practice...
BTW Shawn, I'm in milpitas, you're real close to me. You can come use my bead roller any time! |
#19
the dies bob posted upper die needs to be longer or it will bite in to material
#20
This particular set of dies is meant to do 45 degrees of an arc. So 2 45s welded edge to edge make up a 90 degree bend.
