Old 09-04-2017, 07:34 PM
Jerry Jackson Jerry Jackson is offline
Where do you buy 91% isopropyl alcohol in gallon containers? The pint containers at drug stores gets expensive.
Jerry
Old 09-04-2017, 10:00 PM
Dunno.
How about ....
1. Wick Floor Machine Co
BBB Rating: A+4907 Center Park BlvdSan Antonio, TX 78218
(210) 660-3116
Cleaners SuppliesFloor Machines
WebsiteDirectionsMore Info
From Business: * Repair and Service on All Floor Equipment Rentals on Equipment * Wax * Stripper * Cleaners * Janitorial Supplies * Sand Paper We Accept Cash, Checks, and Major Credit Cards ; Lang:English & Spanish
PREFERRED
2. Cleaning Ideas Corp.
9 San Antonio AveSan Antonio, TX 78201
(210) 551-0296
Chemicals-Wholesale & Manufacturers
WebsiteDirectionsProductsMore Info
From Business: Cleaning Ideas Corp. was started when Joe Davis founded Davis Manufacturing Company in 1929. Joe's first product was a toilet bowl cleaner that he would go business to business taking orders on Monday, mixing the product on Tuesday and make deliveries on Wednesday. As his business increased his customers asked for more typ…
3. Penoles Metals & Chemicals Inc
8301 Broadway StSan Antonio, TX 78209
(210) 824-4600
4. Neuhaus Chemical Products Inc
5727 Mobud StSan Antonio, TX 78238
(210) 684-2411
Website
5. Alamo Laboratories Inc
7795 Mainland DrSan Antonio, TX 78250
(210) 308-0427
Website
6. Noah Technologies Corp
1 Noah ParkSan Antonio, TX 78249
(210) 691-2000
Website
7. Blue Line Corporation
3443 E Commerce StSan Antonio, TX 78220
(210) 354-3701
Website
8. Univar USA
4351 Director DrSan Antonio, TX 78219
(210) 333-7834
9. Grupo Del Toro
1302 Pinn RdSan Antonio, TX 78227
(210) 670-8817
10. Casey Ingredients Inc
10720 Sentinel StSan Antonio, TX 78217
(210) 545-5456
Old 09-05-2017, 01:33 AM
Andy Andy is offline
Richard, I must say that the light in the picture exagerates the 'pits'. It did not look that bad. But I must admit that this weld could be one of the welds I did with a heavy fuel rich flame...just to see what it did.
And yes...I did not think that bad acetylen is an issue here, too. But looking at my current bottle...it is very old. Under the standart color code you can glimpse the old color code of those bottles. So I thought that possible before I startet this thread.
I did weld aluminium with o/a some years back. Different setup, different supplier. No problems. I was just starting back then. I have been welding steel sheet for years now, but with steel dirty ace is not a problem.
As it becomes more and more likely that I will build an aluminium fuel tank in the near future, I wanted to get back into AL welding. Since TIG is not an option for me right now...too expensive and I am in doubt if it is te right thing to use on fuel tanks. I have seen how a steel TIG weld can behave when stressed. And I know what I can do with my o/a steel welds. But I do not want to start this discussion all over again. Both ways have their pro's and con's. The important thing for me is: the weld on a fender or a little hood like the one shown only has to hold the pieces together. The weld on a tank has to be airtight and lasting, largely immune to vibrations and so on.
Originally Posted by elavir View Post
Can it be something else? In this picture the weld doesn't look dirty to me but brittle.
Cheers,
Andy.
If nothing goes right, go left!
Is fhearr fheuchainn na bhith san duil. (It is better to try than to hope!)
Old 09-05-2017, 01:59 AM
Again, nice to see such sauber Verarbeitung.
Thank you for your nette Worte. Or better: Danke für die Blumen.
By the way...do you always have to coat the bottom of the sheet with flux? On a flange weld for examble, could you leave the 'touching' sides uncoated?
Or welding on a bung...do you need flux between the bung and the sheet?
Cheers,
Andy.
Old 09-05-2017, 03:21 AM
dwmh dwmh is offline
Nice job Andy, and I wish my Ali welds were as neat as yours.
I am in the UK but use an acetylene filter anyway (found on Ebay) The same type as Kent sells and I get my filter sleeves from Kent. I like to rule out as many variables as possible.
David Hamer
Old 09-05-2017, 03:41 AM
WOW,
I really didn't think acet could get dirty as I always thought it was the shittyest gas anyway.
Must be like LPG here in OZ, how there throwing to much butane in it just to make it burn and not get hot.
I have noticed this on cars and BBQ;s .........................Lots of problems.
Just a Question, For Kent!
Is it the gas or the crap that is in the bottles when they fill them up.
Sounds like it's going like China, how they add plastic to rice....
Won't be long before a Million dollars will buy you good gas.
Old 09-05-2017, 10:01 AM
Andy,
When welding new aluminum I only flux the rod because when hot, the flux runs like water into all crevices and gaps. Less flux into the weld means less flux to clean up.
John,
I have O/A weld samples going back to 1974 and the welds are very clean until 1989, and then they started getting gray and then even greasy because our local gas was soooo bad.
In the American aircraft factories during the 1930's O/A and O/H were used interchangeably, though on rare occasions the O/H would be specified. I have seen O/A welds on 1950's missiles (Smithsonian) - back when tig was just a kid. There is a difference in the weld appearance between O/H and O/A, but it takes a good (trained) eye to see it.
Old 09-08-2017, 01:30 PM
vroom vroom is offline
Two quick questions:
Does using propane get rid of the dirty gas problem?
Do I need a new regulator to use propane?
Tim Freeman
Old 09-08-2017, 01:41 PM
Hi Tim,
I would not have considered that solution, but I guess so....
If your acet reg fits the threads on the propane can then you are good to go. Otherwise you have to get a fuel reg that fits propane bottles. Acet bottles have about 5 different thread fittings from the century+ that they have been used in different industries - autos, motorcycles, lighting, welding etc.
Old 09-08-2017, 04:35 PM
bobadame bobadame is offline
I've used propane and oxygen to gas weld platinum. That worked great. Then I tried to gas weld aluminum with the same gasses. It didn't work. Don't remember exactly why not but maybe the chemistry was wrong.
Bob
