Old 02-13-2018, 12:46 AM
jhery jhery is offline
Default Drawings and waterjetting hinges
Will Cronkrite made drawings of the hinges and they will be cut out with the waterjet.Name:  BugT57Hinge.jpg
James Hery
Old 02-13-2018, 06:29 AM
Jim
The louvers press is very good design and so is the louvers that it makes..
I think it's a job well done !
Old 02-13-2018, 07:34 PM
Nice work as usual Jim!
Andrew Slater
HANGAR 18 FABRICATION
Old 02-18-2018, 12:00 AM
Default Top panels for hood
The top panels are 54" long so I bought some 4x 10 sheets of aluminum and got 4 panels per sheet. My shear is 52" so it was a little tricky cutting them but by removing the fence and twisting them around I made it work. The dies I made for the Pullmax didn't hold up in delrin so I made them in aluminum. They made small marks on the deep parts but lightly sanded out. After making the body line on the side of the hood the panels were put in the slip rolls, slowly putting an even bow in them to match the cowl panel. The front of the hood has a real sharp bow in it to fit to the horseshoe grill so that will be done with the rubber tire on the wheel. Once that bow is put is done the final body line will be put in with brake. The lower hood hold down panels had been made out of .50 aluminum and were to light so I made them out of .90 and wooden hammer forms to shape the indents.
Name:  2-17-18Protohood 001 Large e-mail view.jpg
Name:  2-17-18Protohood 002 Large e-mail view.jpg
Name:  2-17-18Protohood 003 Large e-mail view.jpg
Name:  2-17-18Protohood 004 Large e-mail view.jpg
Name:  2-17-18Protohood 005 Large e-mail view.jpg
Name:  2-17-18Protohood 006 Large e-mail view.jpg
Name:  2-17-18Protohood 009 Large e-mail view.jpg
Name:  2-17-18Protohood 010 Large e-mail view.jpg
Name:  2-17-18Protohood 012 Large e-mail view.jpg
Name:  2-17-18Protohood 011 Large e-mail view.jpg
Name:  2-17-18Protohood 013 Large e-mail view.jpg
Name:  2-17-18Protohood 014 Large e-mail view.jpg
Name:  8-3-17robwillT57 005 Large e-mail view.jpg
Name:  8-3-17robwillT57 006 Large e-mail view.jpg
Name:  8-3-17robwillT57 007 Large e-mail view.jpg
Name:  8-3-17robwillT57 008 Large e-mail view.jpg
Name:  8-3-17robwillT57 009 Large e-mail view.jpg
Name:  8-3-17robwillT57 010 Large e-mail view.jpg
Name:  8-3-17robwillT57 012 Large e-mail view.jpg
Name:  8-3-17robwillT57 013 Large e-mail view.jpg
Name:  2-17-18Protohood 007 Large e-mail view.jpg
Name:  2-17-18Protohood 008 Large e-mail view.jpg
James Hery
Old 02-18-2018, 09:33 AM
Hi Jim
You make it look easy........ but I know how hard you work!!!!
Hood look better than factory.
Thanks for sharing, so us mortals can try to improve our skills.
Old 02-19-2018, 04:00 AM
Cardiffrob Cardiffrob is offline
Possibly a dumb question...what is the streaked pattern on the metal in the 3rd from last picture?
Rob Thomas,
Cardiff, Wales, UK
Old 02-19-2018, 10:11 AM
The streaking pattern is from the thin paper they place between the sheets. It rained hard after I picked up the load of aluminum and the water ran between the sheets and dried that way but it sand off easily.
James Hery
Old 02-19-2018, 01:12 PM
norson norson is offline
Outstanding! Any chance you have any pictures of the fixture set up for forming the "loop" in the hinges?
Norm Henderson
Old 02-19-2018, 10:44 PM
Default technic to bend hinges
Norson, These photos show the way it is done. I did them on a magnetic brake and a 3/8 steel rod. I first used the brake to wrap around the rod and then I removed the hold-down piece of the brake and tapped it down to finish wrapping it and turned the brake on and it flattened it out. I set the crease with a polished floor chisel. I used .032 brass so it was easy to bend.
Name:  2-19-18abbonds 018 Large e-mail view.jpg
Name:  2-19-18abbonds 019 Large e-mail view.jpg
Name:  2-19-18abbonds 020 Large e-mail view.jpg
Name:  2-19-18abbonds 021 Large e-mail view.jpg
James Hery
Old 02-20-2018, 02:22 AM
Thanks. I have a hood I need to build and this will help a lot. Nice work.
Norm Henderson
