Old 02-09-2013, 02:57 PM
gerry miller's Avatar
gerry miller gerry miller is offline
Default Fender
Hi everyone had to actually cut this whole section out of 1957 pickup fender inner and outer. It was butchered that bad with tons of bondo and make shift reenforcment on back inner brace.Watching MP+C posts helped out a lot. After all the years of being a sculptor in mud this sight has helped me improve a little bit.Still can't gas weld worth a dam but still practicing. I want to get away from grinding and more grinding and more grinding.
Donor Truck Panel cut out..
Cereal box pattern, save old cerial boxes, Lots cheaperBent flange on bench with slapper
Tacked together
Pretty much welded Lots of stretching was required
Getting closer
Gerry Miller
Old 02-09-2013, 04:49 PM
carl 180 carl 180 is offline
hi gerry looks good nice line/wing edge. keep playing with the o/a once you master it you will never look back. very little/no grinding easy to planish
Carl
