Question specific 2 Chicago Electric 90 MIG
Welding / tacking 22 G sheet metal: using only clean, virgin metal.
I have a gas-less Chicago Electric 90 amp MIG with limited settings: MIN / MAX and 0 to 9 feed. Its mild steel Flux Core wire. Using 3/16" hole, plug weld, straight down into the hole with 1/2" lead-in wire method I get too much heat & spatter. I use MIN and 0-1 feed setting. My weld doesn't fill the hole unless given 2-3 seconds, by then its usually over the hole edge & not penetrating well. This makes for a lot of grinding & clean-up. Other than getting a gas rig (no $$$) what can be done to get my settings & technique better on these plug welds using the CE 90 amper??
Robert is Celtic & means 'bright & shining one' - as in new metal " Its Not Kustom Till Its Done ! " EBD Roth "He's a rebel and he'll never never be any good." |
If all you are doing is holding the trigger and not moving you will tend to blow holes...or at least I do. What I like to do is weld a round bead inside the hole, touching the edge of the top part, and filling the hole outside inwards. Do it like any lap weld, just in a circular motion.
No longer driving for a living so its time to dust off the old tools and get crackin'! I'm now spending winter in the Northeast and Summer in Texas??! I think I got it backwards again... Bill F. |
