  #481
Old 02-22-2020, 03:06 PM
Box filling.
Hydro boost unit, master cylinder, wiper motor and cruise control unit.
Old 02-22-2020, 03:09 PM
Wiper motor tubes bent, installed, and a little test run.......
https://www.youtube.com/watch?v=N-erLB3wcPs
Old 02-22-2020, 03:14 PM
Saving the tight bends from the donor hydroboost unit. Welded, dressed and then the small bit of stainless tube that was slid over and tack welded all around on both ends. Air tested for leaks. All good.
Old 02-22-2020, 03:17 PM
Got all the brake and power steering lines bent up and flared. Made a block from aluminum at the exit point.
Old 02-22-2020, 03:30 PM
Looking great, Pugsy. Really great.
Old 02-22-2020, 05:33 PM
THOMAS KINGma THOMAS KINGma is offline
Very nice, just subscribed to your channel
TOM KING I TYPE IN CAPS BECAUSE I AM LEGALLY BLIND
Old 02-23-2020, 04:42 AM
Nice tube bending there.
Old 02-23-2020, 05:17 PM
drivejunk's Avatar
Amazing work, Pugsy.
Matt
Old 03-29-2020, 10:17 AM
Thanks Gentlemen.
A/C brackets bolt to cubby on passenger side.
Old 03-29-2020, 10:19 AM
Drain trough in case I spring a leak. Don't want any fluids running out the front and down the firewall.
