Old 11-11-2016, 11:39 PM
MP&C's Avatar
MP&C MP&C is online now
Default 2016 Maryland Tommasini Metalshaping Class
Sorry for the lack of posts on shop projects, we've been cleaning the shop for the 2016 MD Tommasini Metalshaping Class. Here is a new sand bag we made up for the class, made from a full cow hide, it measures 40" x 24" x 4" high. We had some loose leather left over, so the top was wrapped to provide additional protection from any sharp metal... This uses just over four 5 gallon buckets of saved blast media to fill the bag, so we don't need any holes letting all that pour out on the floor!
Some of the projects include duplicating these repro BMW saddlebags in aluminum, and this Mopar hood in aluminum......
Here Peter shows using the stump for tuck shrinking
Here Peter modifies the heel of a ball peen hammer for less marking while tuck shrinking...
Here it is in use....
https://www.youtube.com/watch?v=plpfX1aPAI0
Duplicating the hood....
A local source was used to CNC a template for bead detail on some Model A p/u bedsides....
Bead added....
Motion picture version:
https://www.youtube.com/watch?v=CSD_RUh6bMg
Close-ups of the results...
1937 Dodge coupe door repairs... the lower inner and lower door skins are fabricated...
A complex architectural piece that was shrunk, stretched, planished, and reverses added, all with the same hammer...
Saddle bags in process...
https://www.youtube.com/watch?v=Fnapwrq0lzw
after wheeling...
Some other efforts of shrinking, blocking, and planishing in making a fender profile and rear corner of a T-bucket in aluminum...
Two days in the books, two to go!
Old 11-12-2016, 06:38 AM
Wow, a lot of productivity going on so far!
Old 11-12-2016, 07:39 AM
WOW! Really neat stuff that you guys are working on. Robert you sure have a well equipped shop. Nice and neat and clean as well. Do you still have that flexible shape pattern in your shop? I know Peter is fond of that metal shaping 'tool'
Old 11-12-2016, 08:51 PM
. Do you still have that flexible shape pattern in your shop? I know Peter is fond of that metal shaping 'tool' [/QUOTE]
Yea ....:rolle yes: love the stuff, really accurate, can not make a panel with out it!!!!
Old 11-14-2016, 07:05 AM
Looks like plenty of learning was going on that week end..
Old 11-14-2016, 08:41 AM
ojh ojh is offline
All kinds of different styles & techniques, that must have been quite a time. Wish I had made it.
oj higgins
Old 11-15-2016, 01:23 AM
MP&C's Avatar
Thanks guys! OJ, Thetan was a real hoot. Would love to work with him on a project or two..
The final two days of the Maryland Tommasini Metalshaping Class. We had two stumps that we gave to students to take home, here is the final version carved....
https://www.youtube.com/watch?v=5yH-M21yUok
I had some requests to show the mammoth sand bag with the loose cover removed... It saw quite a bit of use and came in handy!
More repair parts were made for the 37 Dodge doors...
The crease or "swage" at the top center of the hood was difficult to locate through the paper pattern.
So the upper and lower "crease" was highlighted by using fineline tape alongside. Then a pencil was used on the outside of the paper pattern, which now showed the location. Better shown here:
https://www.youtube.com/watch?v=miZW1aOWwXg
The halves still need to be welded together using O/A.
Two of the ball glove pounding pads were put into service for metalshaping, one using shot, the other using sand..
Peter showed lead loading method for aluminum...
Old 11-15-2016, 08:44 AM
Huh, Peter must have been doing that aluminum leading lesson while I was sleeping at Will's..... Seriously, I am curious- does the leading process involve enough heat to anneal the aluminum and thus require any additional steps?
Thanks for posting great pics and video links. The hood process & details mentioned, thin line tape, etc. are relevant to a project I have here. It's very much on the back burner, but at least now I have a better strategy if it progresses.
Old 11-15-2016, 10:54 AM
I guess I must have been sleeping.... I did not know that you could lead aluminum. I'd like to know more. Is that covered in one of Peter's DVDs and, if so, which one.
If this has been discussed here before, I must have missed it.
Old 11-15-2016, 11:44 AM
bobadame bobadame is offline
Peter demonstrated this process last year at the Colorado class. The bond is very strong. The piece can be bent and it all stays together. From what I remember the process is very similar to leading steel.
Bob
