Old 01-24-2018, 10:44 PM
Payupv8 Payupv8 is offline
So I should go back over the undercut areas and add some filler rod and then rework the distortion if there is any? I was wondering if I should do that I just didn't want to cause anymore problems
Eric Crafton
Old 01-25-2018, 01:55 AM
That is what I always do.
Old 01-25-2018, 03:03 PM
Thank you for all the tips I'll do that then.
Eric Crafton
Old 01-25-2018, 06:06 PM
outsider347 outsider347 is offline
Noob here as well
What do you guys think about O/A welding the divots with a soft malleable filler, proper hammer work & planish
Ed
"To Be or To Do" John Boyd
Old 01-25-2018, 06:26 PM
AllyBill AllyBill is offline
Originally Posted by outsider347 View Post
Noob here as well
Can you get a MIG set and just spot over the top? It's fast and only heats the bit you want to mend without penetration you don't need. OA is too slow, it'll burn the back of the panel.
Here to learn.
William Pointer
Old 01-26-2018, 10:56 AM
red baron's Avatar
Mig is a good way to fill in the undercut from the weld.... so is adding filler rod with the tig.
Mike Mettelka
Mettelka Craft Metalshaping
Wanted, 41 Cadillac Fleetwood
Old 01-26-2018, 01:28 PM
I figured I'd use my tig to fill the undercut, I need the practice with my tig any ways
Eric Crafton
Old 01-26-2018, 07:07 PM
You can always braze or solder too if you just want to be rid of the blemishes but as it's not structural why not throw it at the paint shop and let them disappear it?
So easy to see it as your failing when it's bread and butter to another trade who'll enjoy showing you how they got rid of it - let them do the work.
Here to learn.
William Pointer
Old 01-27-2018, 03:40 AM
Just use 0.6 or 0.9 mig wire as your tig filler rod to fill them. Less heat needed to melt the rod.
Old 02-02-2018, 11:27 AM
It came out better, I still need lots of practice, as I think my skill set is my limiting factor. It seems like the last little bit is the hardest. Good thing this fender is for my personal car because it took me for ever to get to this point
Eric Crafton
