Old 08-22-2019, 12:18 PM
sru_tx sru_tx is offline
MetalShaper of the Month November 2017
I agree with maxakarudy that Wray might have gotten a bit ahead of himself by putting the joggles in and locking the arrangement.
One thing that I found interesting is that in 5A and B he did not do any additional stretching/shrinking after getting the FSP fitting properly. A few minutes at the beginning to stretch the nose opening as per the FSP and the rest of the video was all arrangement. I'm sure the can/will be tweaks at the end but the piece is very close as is.
Better to be a learn-it-all than a know-it-all
Facebook Page: fab.weld.wood
WWW: http://www.fabweldwood.com
Old 08-22-2019, 01:45 PM
dwmh dwmh is offline
I am a fan of Wray's FSPs and do use them at times, as he says you can do your stretching and shrinking and work it out of arrangement and be sure you have the right area change.
However I too was surprised he locked the shape in with the headlamp joggle before checking with the profile gauges that the arrangement was correct. However with his expertise, he can no doubt fix it.
David Hamer
Old 08-22-2019, 04:47 PM
neilb's Avatar
neilb neilb is offline
Originally Posted by toreadorxlt View Post
That is the magic of the FSP and why wray loves it. It looked like barrel and that was only arrangement. It looked like a barrel for a reason, so he could fit the lowest crown die in thats possible. He was able to check shape and get the shape right then he was able to set arrangement.....
I understand what your saying but at the end of the 4th video it has too much shape in it still, which means he put too much shape in it, that is a fact plain and simple. so the FSP told him nothing otherwise he would have stopped putting shape in it.
Neil
Old 08-22-2019, 07:30 PM
mastuart mastuart is offline
Niel No not enough shape yet. Watch part 5a and 5b. This system tell you exactly where to shrink and stretch. The guys that know how to use them make it look like magic. I have seen someone make a part for the wrong side turn it inside out and use it on the other side. I haven't seen anyone use a paper pattern that did not have to check progress lots of time by fitting to the buck or other parts . A FSP when it fits the part it is right.
Mark
Old 08-23-2019, 01:43 PM
Been following this and surprised no one has said this yet so I guess I will. Paper patterns and FSP are 2 different things and actually could compliment each other in shaping something. A paper pattern to me is a road map. Tells me where to bend, stretch/ shrink put a return, how big of a blank to cut, etc. etc. A flexible shape pattern would be more like a buck used in place of profiles that you would use when shaping a piece with a paper pattern alone. So a more apt comparison would be between making profiles of a panel and a FSP. I think though that a FSP is fairly limited to small pieces whereas using a traditional method such as paper patterns and profile gauges is more suited to both large and small pieces.
I think that what bothers Neil and others is that FSP's are recommended by some to novices who don't have the experience to understand what the FSP is telling them. For a novice it would seem paper patterns and profiles would be a far more efficient and successful way to approach making a panel.
Old 08-23-2019, 05:09 PM
neilb's Avatar
can someone post a video of anyone making a part with an FSP where the part does not yet exist? no wooden buck to work from and no old part to work from. i am interested in how they would go about producing the FSP to then make the part needed
Neil
Old 08-23-2019, 05:13 PM
neilb's Avatar
Originally Posted by mastuart View Post
Neil No not enough shape yet. Watch part 5a and 5b. This system tell you exactly where to shrink and stretch. The guys that know how to use them make it look like magic. I have seen someone make a part for the wrong side turn it inside out and use it on the other side. I haven't seen anyone use a paper pattern that did not have to check progress lots of time by fitting to the buck or other parts . A FSP when it fits the part it is right.
i don't think i am ready to watch parts 5 yet, the quote ''A FSP when it fits the part it is right.'' is true, but then so is the quote if i buy a pair of shoes the same size as my feet they will fit, or a shirt or a coat... the list goes on
Neil
Old 08-23-2019, 11:11 PM
Niel can you do the same for me with a paper pattern? I think It would be hard to make a paper pattern of a imaginary part. Question...…...At what point when using a paper pattern does the part fit? Can you make a part with a paper pattern and not have to check to see if it will fit until the part is done?
Mark
Old 08-24-2019, 12:31 AM
neilb's Avatar
Neil can you do the same for me with a paper pattern?
yes .
Neil
Old 08-24-2019, 10:05 AM
Not a video but here is a post of using a 'Burt Buck' named after the late Ken Burt. http://allmetalshaping.com/showthrea...uck#post131055
I used it to help make the basic shape and refined by eye. I then made a FSP of the finished part, turned it inside out, and used that to make the mirror image for the other side.
Works for me.
I get that you don't get it, but please accept that some folks do and there are lots of ways to shape metal and no single way is the 'right way' or the 'only way'.
