#341
Do you have a link? I went to the site but didn't see anything larger than would be used in a die grinder.
#342
6" Nylon Bed Liner Prep Brush
Eric Z. |
#343
Yes, that is it.
I tried to get the link on my iPad but it did not work for me. So I gave the site name. You may be able to find the same or similar brush elsewhere. Once you use it you will like it. Mike Thanks for the link. |
#344
We had some difficulty wheeling the skin for the deck lid. The panel is large and we were leaving edge marks from the lower anvil. I think I can save this panel but I need to make some training wheels like Frank's. I have some parts ordered for them so in the mean time I'm going to go ahead with the gutters and inner rear panel. I can finish the deck lid skin when I get my parts.
#345
I notched the buck to accept the gutters and trimmed the ends to size. Then made a template for the inner rear panel.
#346
The inner rear panel didn't need much shaping. I just tipped the flange and stepped the rear edge. The rear edge will be lapped, plug welded and finished with seam sealer.
#347
Looking good Jack. Thise training wheels work. But if your lower has a nasty edge maybe putting in a nice releave could also be helpfull. I needed my training wheels also because the sides if my upper were digging in. That can happen if your upper is wider dan your lower. But I've also put a releave on the upper's edge also. Only the inner because it was just a bit too sharp. My design so ky fault ;-)
Good idear to nodge the buck. I'm planning a 3d file of the bug and was way too overcomplicating the design. Just nodging by hand when you need sound way better. Greetings, Frank
Frank de Kleuver |
#348
Any pictures of a 'training wheels' Frank?
#349
Sure,
But they are on MM. I hope this is allowed. Otherwise I'll try to upload it. http://www.metalmeet.com/forum/album.php?albumid=742 http://www.metalmeet.com/forum/showthread.php?t=12440 Greetings, Frank
Frank de Kleuver |
#350
That's something I need for sure. I can't wheel a large panel for beans. |
