Old 08-27-2016, 11:18 AM
foxauto foxauto is offline
Default Help picking O/A regulators
My ancient Marquette's are about to give up the ghost, I would like to buy a good set of regulator's that would allow me to adjust down to the low pressures needed with say a Meco type torch but also work well when adjusted up for standard type torches for like general auto repair type stuff, heating nuts, cutting spring hangers etc.. O/A sheetmetal welding is something new I want to learn and having both capabilities would be nice, is it possible to have both in the same regulator?
Doug
Old 08-27-2016, 12:23 PM
Avoid the generic regs and go for the main brands - Smith, Harris, Victor, etc.
Since welding torches require 1-6psi, and cutting requires 8-15psi, the regulator is needed to accurately cover a broad range - especially since the secondary (outlet) side gauge is 0-100 psi, and is only being used at a fraction of that. Having a name brand reg is a good start. Prices range from $80 each for single stage to $250 each for the dual stage models.
You don't have to buy "low -pressure regs" for welding, because you can use the secondary knob on the reg to set your torch and ignore the gauge - which is not accurate at all at pressures less than 10psi.
This is an old aviation method: http://www.tinmantech.com/products/w...dget-torch.php
If you can find an add-on reduction regulator for the oxygen side, it should take the outlet gas pressure from there and meter it accurately to 0-30psi.
For instance: http://www.ebay.com/itm/WELDING-PRES...IAAOSwTapV3L2k
Hope this helps,
Old 08-27-2016, 01:57 PM
That link takes you to a gauge for a regulator, do you have a suggestion for the regulator, itself?
mjb
Marc
Old 08-27-2016, 02:19 PM
I'm looking at whole outfits as my whole setup needs upgraded, what do you think of this.http://store.cyberweld.com/vime350wecuo.html
Doug
Old 08-27-2016, 06:26 PM
Cheap enough, so might as well go for it. Work out the missing bits later.
