  #31
Old 06-06-2019, 08:55 PM
That's a good idea Ken. You could also possibly wind it with mig wire and solder the ends. I have seen something like that before, but I recall where.
ærugo nunquam dormit
Old 06-06-2019, 10:31 PM
qkiss qkiss is offline
MetalShaper of the Month February 2020
Location: Fortuna California -- up north behind the redwood curtain
What RPM is your grinder? Some grinders run faster than others. Not all brands run at the same RPM. Just a thought
Steve Kioukis
Sometimes your mind is stretched out of shape by a new idea never to go back to its original form.
Old 06-13-2019, 07:52 PM
Nawrocki Fabricating Nawrocki Fabricating is offline
Default Wood shrinking disc
Last twenty years I used a clutch disc for friction shrinking. It is 9'' disc on 6000 rpm machine. Seven years ago I came up with an idea of a smaller diameter wood disc. The big one use on large open areas. The small one was used in difficult spots and corners. Now I made a new wooden disc, 4.5'', from maple and glued it with JB glue to a steel plate. The friction shrinking is used mainly for restoration the old steel, and very rarely on aluminium. The small machine runs on 9000 rpm.IMG_20190612_141543814 (1).jpg
Cass
Old 06-13-2019, 10:47 PM
fred26t fred26t is offline
Default Clutch disk caution!
Many (older) clutch disks are made with asbestos. Not good at all. I don't know of any dust mask that will remove or filter it out. Fred26t
Fred26T
Old 06-14-2019, 10:30 AM
Good point. I made sure that NO asbestos when replaced mine.
Cass
Old 06-14-2019, 10:52 AM
P100 masks will capture airborne particulate larger than 0.3 microns and, unlike an N100 mask, still function in the presence of oil. P100 are HEPA rated and remove at least 99.97% of airborne particulate. https://www.cdc.gov/niosh/npptl/topi...t/default.html
To better guarantee the cleanest air, an external source forced air respirator is the safest source of breathable air in contaminated environment. Even the best forced air respirator will be normally sourcing air through a HEPA rated intake filtering system and P100 is the highest rating offered for such filters....
A P100 half-face unit with replaceable filter cartridges isn't prohibitively expensive or significantly cumbersome. whatever the situation, particulate masks do not protect against vapor.
Old 02-28-2021, 06:16 PM
2020Presence 2020Presence is offline
Many thanks to the good people on this forum.
Dennis from I.E., California
'51 Ford F1 Project
1966-77 Broncos
Here to learn
Old 03-11-2021, 01:30 PM
TonyP TonyP is offline
Default UHMW instead of wood?
Anybody tried it?
I have found this whole thread very informative and appreciate all the info.
Tony
Old 03-11-2021, 08:46 PM
Originally Posted by TonyP View Post
Anybody tried it?
Hi,
I use mine often when repairing aluminium with great results.
Bill
Bill Tromblay
Old 03-11-2021, 11:19 PM
Hi Bill.
Sorry as a noob here I’m not familiar with this forum format so I kind shot a blank and put UHMW in the title field so I don’t think it was clear what I was asking.
So has anybody tried UHMW instead of wood on a shrinker pad?
I have some hard maple from a futon frame. But I also have a lot of 1” thick sheet UHMW.
Tony
Tony
