  #41
Old 02-27-2018, 08:55 AM
I was recently with one man in the workshop. He had a very old car there - valuable. I was looking at his work. I saw that instead of wood, the door was filled with metal. On my question why? He said literally, a cough on the wood, there is a lot of work ...... and for the money he gives me what he wants .....
When I see how you have to chop the forest and drive out the worms .. Beautiful work.
This dismantled wood beautifully and inconspicuously burns even after hours of leaving the workshop. I did not believe it was possible.
Old 02-27-2018, 11:29 AM
Kevinb71 Kevinb71 is offline
James I am in awe of the dedication and skill that are going into this car. If I can ask, what is a Drophead coupe? Watching this progress. Thanks for your time to share.
Kevin B
Old 02-27-2018, 05:28 PM
I had the same question and solved it with Google.
"1924 Rolls Royce Drophead Coupe"
Marc
Old 02-27-2018, 05:38 PM
Drophead is the English name for a convertible; confusingly small convertibles such as Morris Minors, were called Tourers,
Cheers Charlie
Old 03-01-2018, 11:45 PM
jhery jhery is offline
Default Cowl vent
The cowl vent was fabricated out of brass and the gutter system is cast aluminum. It had two 1/4" countersunk screws holding it to the frame work. They dimpled the cowl vent on either end for the screws and for some reason there was a 1/2" hole right in the center which I soldered a brass patch in. I tinned all the part to be soldered and mounted everything together and then soldered the screws and the patch with silver bearing solder. when that was cool I leaded over all of the low spots and removed the frame from the vent and soldered the brackets on the backside.
I used hot water to clean the acid off and glass beaded the whole vent, reassembled and filed the top straight. The two wood stringers were cut and everything was fitted.
Name:  3-1-18abbondssr 001 Large e-mail view.jpg
Name:  3-1-18abbondssr 002 Large e-mail view.jpg
Name:  3-1-18abbondssr 003 Large e-mail view.jpg
Name:  3-1-18abbondssr 004 Large e-mail view.jpg
Name:  3-1-18abbondssr 005 Large e-mail view.jpg
Name:  3-1-18abbondssr 006 Large e-mail view.jpg
Name:  3-1-18abbondssr 007 Large e-mail view.jpg
Name:  3-1-18abbondssr 008 Large e-mail view.jpg
Name:  3-1-18abbondssr 009 Large e-mail view.jpg
Name:  3-1-18abbondssr 010 Large e-mail view.jpg
Name:  3-1-18abbondssr 011 Large e-mail view.jpg
Name:  3-1-18abbondssr 012 Large e-mail view.jpg
Name:  3-1-18abbondssr 013 Large e-mail view.jpg
Name:  3-1-18abbondssr 014 Large e-mail view.jpg
Name:  3-1-18abbondssr 015 Large e-mail view.jpg
James Hery
Old 03-02-2018, 09:00 AM
Looks gooo Jim!
Where there is a will there is a way!
Thanks for sharing.
Old 03-02-2018, 09:27 AM
Looks great, Jim. Did you have to pattern and cast the aluminum gutter as well or were you able to use an existing piece?
Old 03-08-2018, 05:52 AM
Really enjoyed learning the way a timber frame vehicle goes together. Thank you for taking the time to share it.
Old 03-26-2023, 08:57 PM
Default 1936 Mayfair
It has been a few years since I have posted anything on this car. Unfortunately the owner had an accident and was killed so the family has decided to finish the car so I will start posting more photos of the progress.Name:  abbonds 001 Large e-mail view.jpg
Name:  abbonds 002 Large e-mail view.jpg
Name:  abbonds 003 Large e-mail view.jpg
Name:  abbonds 004 Large e-mail view.jpg
Name:  abbonds 005 Large e-mail view.jpg
Name:  abbonds 006 Large e-mail view.jpg
Name:  abbonds 007 Large e-mail view.jpg
Name:  abbonds 008 Large e-mail view.jpg
Name:  abbonds 009 Large e-mail view.jpg
Name:  abbonds 010 Large e-mail view.jpg
Name:  abbonds 011 Large e-mail view.jpg
Name:  abbonds 012 Large e-mail view.jpg
Name:  abbonds 013 Large e-mail view.jpg
Name:  abbonds 014 Large e-mail view.jpg
Name:  abbonds 015 Large e-mail view.jpg
Name:  abbonds 016 Large e-mail view.jpg
Name:  abbonds 018 Large e-mail view.jpg
Name:  abbonds 017 Large e-mail view.jpg
Name:  abbonds 019 Large e-mail view.jpg
Name:  abbonds 020 Large e-mail view.jpg
Name:  abbonds 021 Large e-mail view.jpg
Name:  abbonds 022 Large e-mail view.jpg
Name:  abbonds 023 Large e-mail view.jpg
Name:  abbonds 024 Large e-mail view.jpg
Name:  abbonds 025 Large e-mail view.jpg
Name:  abbonds 026 Large e-mail view.jpg
Name:  abbonds 027 Large e-mail view.jpg
Name:  abbonds 028 Large e-mail view.jpg
Name:  abbonds 029 Large e-mail view.jpg
Name:  abbonds 030 Large e-mail view.jpg
Name:  abbonds 031 Large e-mail view.jpg
Name:  abbonds 033 Large e-mail view.jpg
Name:  abbonds 034 Large e-mail view.jpg
Name:  abbonds 035 Large e-mail view.jpg
Name:  abbonds 036 Large e-mail view.jpg
Name:  abbonds 037 Large e-mail view.jpg
Name:  abbonds 038 Large e-mail view.jpg
Name:  abbonds 039 Large e-mail view.jpg
Name:  abbonds 040 Large e-mail view.jpg
Name:  abbonds 041 Large e-mail view.jpg
Name:  abbonds 042 Large e-mail view.jpg
Name:  abbonds 043 Large e-mail view.jpg
Name:  abbonds 044 Large e-mail view.jpg
Name:  abbonds 045 Large e-mail view.jpg
Name:  abbonds 046 Large e-mail view.jpg
Name:  abbonds 047 Large e-mail view.jpg
Name:  abbonds 048 Large e-mail view.jpg
Name:  abbonds 049 Large e-mail view.jpg
Name:  abbonds 050 Large e-mail view.jpg
Name:  abbonds 051 Large e-mail view.jpg
Name:  abbonds 052 Large e-mail view.jpg
Name:  abbonds 053 Large e-mail view.jpg
Name:  abbonds 054 Large e-mail view.jpg
Name:  abbonds 055 Large e-mail view.jpg
Name:  abbonds 057 Large e-mail view.jpg
Name:  abbonds 058 Large e-mail view.jpg
Name:  abbonds 059 Large e-mail view.jpg
Name:  abbonds 060 Large e-mail view.jpg
Name:  abbonds 062 Large e-mail view.jpg
James Hery
Old 03-26-2023, 09:37 PM
Reconstructing the wood and bracing on rear section of car
Name:  abbonds 063 Large e-mail view.jpg
Name:  abbonds 064 Large e-mail view.jpg
Name:  abbonds 065 Large e-mail view.jpg
Name:  abbonds 066 Large e-mail view.jpg
Name:  abbonds 067 Large e-mail view.jpg
Name:  abbonds 068 Large e-mail view.jpg
Name:  abbonds 069 Large e-mail view.jpg
Name:  abbonds 070 Large e-mail view.jpg
Name:  abbonds 071 Large e-mail view.jpg
Name:  abbonds 072 Large e-mail view.jpg
Name:  abbonds 073 Large e-mail view.jpg
Name:  abbonds 074 Large e-mail view.jpg
Name:  abbonds 075 Large e-mail view.jpg
Name:  abbonds 076 Large e-mail view.jpg
Name:  abbonds 077 Large e-mail view.jpg
Name:  abbonds 078 Large e-mail view.jpg
Name:  abbonds 079 Large e-mail view.jpg
Name:  abbonds 080 Large e-mail view.jpg
Name:  abbonds 081 Large e-mail view.jpg
Name:  abbonds 082 Large e-mail view.jpg
Name:  abbonds 083 Large e-mail view.jpg
Name:  abbonds 084 Large e-mail view.jpg
Name:  abbonds 085 Large e-mail view.jpg
Name:  abbonds 086 Large e-mail view.jpg
Name:  abbonds 087 Large e-mail view.jpg
Name:  abbonds 088 Large e-mail view.jpg
Name:  abbonds 089 Large e-mail view.jpg
Name:  abbonds 090 Large e-mail view.jpg
Name:  abbonds 091 Large e-mail view.jpg
Name:  abbonds 092 Large e-mail view.jpg
Name:  abbonds 093 Large e-mail view.jpg
Name:  abbonds 094 Large e-mail view.jpg
Name:  abbonds 095 Large e-mail view.jpg
Name:  abbonds 096 Large e-mail view.jpg
Name:  abbonds 097 Large e-mail view.jpg
Name:  abbonds 098 Large e-mail view.jpg
Name:  abbonds 099 Large e-mail view.jpg
Name:  abbonds 100 Large e-mail view.jpg
Name:  abbonds 102 Large e-mail view.jpg
Name:  abbonds 103 Large e-mail view.jpg
Name:  abbonds 104 Large e-mail view.jpg
Name:  abbonds 105 Large e-mail view.jpg
Name:  abbonds 106 Large e-mail view.jpg
Name:  abbonds 107 Large e-mail view.jpg
Name:  abbonds 108 Large e-mail view.jpg
Name:  abbonds 109 Large e-mail view.jpg
Name:  abbonds 110 Large e-mail view.jpg
Name:  abbonds 111 Large e-mail view.jpg
Name:  abbonds 112 Large e-mail view.jpg
Name:  abbonds 113 Large e-mail view.jpg
Name:  abbonds 114 Large e-mail view.jpg
Name:  abbonds 115 Large e-mail view.jpg
Name:  abbonds 116 Large e-mail view.jpg
Name:  abbonds 117 Large e-mail view.jpg
Name:  abbonds 118 Large e-mail view.jpg
Name:  abbonds 119 Large e-mail view.jpg
Name:  abbonds 120 Large e-mail view.jpg
Name:  abbonds 121 Large e-mail view.jpg
Name:  abbonds 122 Large e-mail view.jpg
Name:  abbonds 123 Large e-mail view.jpg
Name:  abbonds 124 Large e-mail view.jpg
Name:  abbonds 125 Large e-mail view.jpg
Name:  abbonds 126 Large e-mail view.jpg
Name:  abbonds 137 Large e-mail view.jpg
Name:  abbonds 139 Large e-mail view.jpg
Name:  abbonds 138 Large e-mail view.jpg
Name:  abbonds 140 Large e-mail view.jpg
Name:  abbonds 141 Large e-mail view.jpg
Name:  abbonds 142 Large e-mail view.jpg
Name:  abbonds 143 Large e-mail view.jpg
Name:  abbonds 145 Large e-mail view.jpg
Name:  abbonds 146 Large e-mail view.jpg
Name:  abbonds 147 Large e-mail view.jpg
Name:  abbonds 148 Large e-mail view.jpg
Name:  abbonds 149 Large e-mail view.jpg
Name:  abbonds 150 Large e-mail view.jpg
Name:  abbonds 151 Large e-mail view.jpg
Name:  abbonds 152 Large e-mail view.jpg
Name:  abbonds 154 Large e-mail view.jpg
Name:  abbonds 155 Large e-mail view.jpg
Name:  abbonds 156 Large e-mail view.jpg
Name:  abbonds 158 Large e-mail view.jpg
Name:  abbonds 159 Large e-mail view.jpg
Name:  abbonds 160 Large e-mail view.jpg
Name:  abbonds 161 Large e-mail view.jpg
Name:  abbonds 162 Large e-mail view.jpg
Name:  abbonds 163 Large e-mail view.jpg
Name:  abbonds 164 Large e-mail view.jpg
Name:  abbonds 165 Large e-mail view.jpg
Name:  abbonds 166 Large e-mail view.jpg
Name:  abbonds 167 Large e-mail view.jpg
Name:  abbonds 168 Large e-mail view.jpg
Name:  abbonds 169 Large e-mail view.jpg
Name:  abbonds 170 Large e-mail view.jpg
Name:  abbonds 171 Large e-mail view.jpg
Name:  abbonds 172 Large e-mail view.jpg
Name:  abbonds 173 Large e-mail view.jpg
Name:  abbonds 174 Large e-mail view.jpg
Name:  abbonds 175 Large e-mail view.jpg
Name:  abbonds 176 Large e-mail view.jpg
Name:  abbonds 178 Large e-mail view.jpg
Name:  abbonds 179 Large e-mail view.jpg
Name:  abbonds 180 Large e-mail view.jpg
Name:  abbonds 181 Large e-mail view.jpg
Name:  abbonds 182 Large e-mail view.jpg
Name:  abbonds 183 Large e-mail view.jpg
Name:  abbonds 184 Large e-mail view.jpg
Name:  abbonds 185 Large e-mail view.jpg
Name:  abbonds 186 Large e-mail view.jpg
Name:  abbonds 187 Large e-mail view.jpg
Name:  abbonds 188 Large e-mail view.jpg
James Hery
