Old 05-23-2014, 10:30 PM
JohnStubbe JohnStubbe is offline
Default Metalshaping used for Function/Mechanical- anyone doing it?
So I've been dinking around with an intake and had to use some shaping to make the runners, but very minimal really. Most intakes are basically simple tubes with the ends made to fit the port. Nothing really shapped, just re-arranged. It did get me wondering if any of you guys are making serious shaped runners,peices, whatever that serve a functional purpose? As in not just for asthetics/like most car bodies.
For example I'm sure some of you could build a turbo manifold that has beautiful sweeping tubes that also taper down smoothly and have almost no real transition points. Anyone doing this stuff
Also If OT or wrong place no prob,del or move
John Stubbe
Into classic cars and speed, Went to Hot Rod Institute
Old 05-23-2014, 10:38 PM
bobadame bobadame is offline
Haven't yet, but I will need to make the runners to add an inter cooler to the Deutz engine in my bus.
Old 05-23-2014, 11:12 PM
Jim, sent you a PM.
Old 05-24-2014, 06:30 AM
I made a pretty complex radiator shroud for the roadster a few years back. It is an offset square to round with a weird relief for the upper radiator hose with a bunch of brackets and flanges. It also had to come apart in order to be removed.
Old 05-24-2014, 12:42 PM
DanGunit's Avatar
DanGunit DanGunit is offline
Hey John,
I do quite a bit of this for guiding air/water/fire flow, the shaping allows me to form the organic curves I need to get the best unobstructed flow through changing directions and volumes. I couldn't get the required performance using straight formed or fabricated sections. Unfortunately I can't show pictures at the moment because the products and processes are proprietary and confidential until we finish testing and patenting the units, but trust me, it can really enhance the performance and aesthetics of your project at the same time if that is what you are after and you test your designs and refine them for performance.
Daniel Gunderson
Old 05-24-2014, 01:39 PM
Hi John,
I made an aluminum intake runner that connected a Holley 385cfm 4bbl to a Holset turbocharger one time. It had a twisting flow that carried through an 160deg angle into a 2.5"id aluminum pipe. It was a combination of patterns to make the "leaves", then cut, fit and tacked them together. Adjustments made, then welded, then adjusted again. It was a very smooth piece at the end and gave no indication that it was worked so much into the final shape after welding. The gasweld beads were left flat and untouched and I bead-blasted the whole thing so it was decent to look at. I did the same for the header collector, but it was steel and mated the 8 pipes into the turbo hot section.
It was the only gas turbo I ever heard that whistled like a big diesel truck when it went into its 14psi boost, but that diesel snail was rated at 120K rpm. (Made over 450hp for 75K miles, until I gave it to my son.)
Old 05-24-2014, 07:31 PM
Richard-S Richard-S is offline
Member MetalShaper of the Month Nov 2013
Ron Fournier has an excellent chapter in one of his two metal shaping books (I don't remember which and the books are at my shop up in California) that covers his making an intake manifold for an experimental engine built by Ford. He made it from steel sheet metal on hammer forms.
When I die heaven can wait, I want to go to McMaster-Carr.
My sculpture web page http://www.fantaciworks.com
Old 05-24-2014, 08:07 PM
Also worth mentioning is maybe the old Myron Stevens footage of him making up the steel sheet straight-eight exhaust header set for the Miller 91 - out of what, one sheet of tin? I heard about the Miller guys doing that using a welded machined mandrel, but by hand is a load of thumping. Better to have flow forming in the tool box for that job.
