Old 04-15-2020, 04:01 AM
Perfect work Kent. Your dimensions are big.
I found an interesting video from the industry. But he won't show the tool.
https://www.youtube.com/watch?v=1egmm_4Y3Rk
Old 04-15-2020, 07:21 AM
red baron's Avatar
I like your rolling table top, willing to give any info on it?
Mike Mettelka
Mettelka Craft Metalshaping
Wanted, 41 Cadillac Fleetwood
Old 04-15-2020, 09:47 AM
Hi Mike,
I got the two tables, complete, from this outfit:
https://www.cisco-eagle.com/catalog/...nters-35-frame
After also considering:
https://www.hytrol.com/Products/Accessories/Transfers
Timely delivery with table height needed, leg angle variability and ball-ball distance of 4in.
Old 04-15-2020, 10:11 AM
Thanks Jaro.
Back when I first started this job .... I was thinking that since I have (distant) access to a 10ft. power roll with 6in dia. rolls and so I thought - with a stack of metal I could experiment and then push buttons instead of metal. I thought about it for so long that I started with what I had ....
Choices, always choices ....
Old 04-15-2020, 01:57 PM
Default "Setting the shape"
"Setting the shape"
I don't see this topic covered enough.
I have been working this technique as part of my Plan during this job, as it is essential for this type of part (16ga CR steel).
"Make a plan, work the plan, stick to the plan" -(told to me during a TX wksp by a long-time Texas oilfield fabricator.)
Working the shape in the Hammer
"arranging the shape" on the form
"Setting the shape" using a hand hammer.
Checking the fit
Using a straight edge goes back to the original model, analyzing the shape as it is.
"Setting the shape" is a term from the "pressforming" industry.
On thicker-than-autobody steel sheet currently in usage, the press dies come together slowly as the part is pressed, and as the steel work-hardens the press speed picks up a little bit. When the dies close, the press opens a bit and then thumps closed for a final time, "setting the shape."
At the college levels of materials science, terminology such as "elastic", "plastic/elastic", and "plastic deformation" are used to describe materials/metals being formed into shapes.
https://en.wikipedia.org/wiki/Deformation_(engineering)
(As part of our 4DayWorkshop Trainings students are issued "prep materals" which include, but not limited to, DVD instruction covering materials science and stretch forming.)
Hence, "arranging the shape" is separate from "setting the shape."
Old 05-27-2020, 06:49 PM
Default basic twist
Forgot to include the basic twisted ribbon shape.
This is just a 2in wide X 36 long piece of .050 3003, marked lengthwise for two working widths of one-third total width, each. These edges are hammered consistently one end to the other, matching each other. The center one third is pretty much untouched. If your hammer blows are evenly spaced, evenly struck, and numerically match one side to the other then your twist will be even.
If not, then you get odd.
(ps, if you scrutineer closely you see one black center line .... I just eyeball off of the centerline for my thirds as I go. )
Old 05-28-2020, 03:19 AM
Kent. I see you won't show us any cars for a long time.
Are you making someone DNA? A monument to someone in particular? For example, knocked man monument?
That job looks on long time work.
Old 05-28-2020, 05:35 AM
Wow, that is one big long commision to undertake. I admire you for taking on things like this.
Old 05-28-2020, 12:05 PM
Jaro, I posted some car stuff a few weeks back - the Porsche GT3 racer with its new 4 corners in aluminum .
Otherwise, I come in each day and hammer accurately and consistently on the September Job,
8 large steel helical panels.
(and there are no "rapid traverse" choices on my machinery.... )
Old 05-28-2020, 12:35 PM
Coming from yourself, Marcus, this observation is sincerely acknowledged.
#6 is 90% done with 90% left to go, as airplane builders are fond of saying.
The last 10% is getting the complete fit to spec. Major nitpicking now, as the entire panel is in tension, like a set of piano strings - linear as they also are - and change the tension on either the box - or the board - or a group of 3 or 2 strings - and the rest of the strings respond.
Today I am getting again used to my "acquisition d'attire," last worn in March.
