Hey Bob: I built the same wheel from the site but my steering shaft if really loose and I was wondering from looking at yours, are the two dots really set screws to tighten it up. Also I have found that the holder for the bottom anvil is to wide and then the nut and bolt head make it worse, so I can't make very much curve on it. I think I am going to cut it down and maybe just put a pin in it like a larger wheel, then I can taper a couple of bearings for different wheeling jobs. Also built with the bottom anvil on the straight rail of the frame does not work with a bench mounted vise. It makes it too tall to use comfortably. I have to use mine upside down which works, butttttt you know/!
Mike Last edited by Mike Hendrix; 11-10-2012 at 01:06 PM. Reason: left out something |
#13
Here is a link to one I built, works but is too heavy.
http://allmetalshaping.com/showthread.php?t=352
#14
So Joe: Knowing you I would expect a new one or at least one in the works. Love to look at your work.
Mike |
