Old 04-11-2012, 05:05 AM
Dale in aus Dale in aus is offline
Default pic test
lets see if this works
Cheers Dale
Dale Goldfinch
Adelaide, South Australia
Old 04-11-2012, 06:24 AM
Almost there Dale.
The last step is to put your cursor where you want the photo, then click on the paperclip again, and select the photo you want in that spot. OR click on insert all at the bottom of the paperclip list and write your text around the photos. That is what I do.
Old 04-11-2012, 07:42 AM
Almost there Dale.
Thanks Kerry...
I have just put a post up for the contest but I did eveything the same and inserted them where likeyou said but none of them have worked...
can you help?
Dale Goldfinch
Old 04-11-2012, 09:02 AM
I see you figured it out.
