Old 01-17-2018, 09:58 PM
Default Skill builder Ewheel practice panel oil can issue
Hi,
I was fortunate last Saturday to spend time with Joe Stafford of Panel Craft in New Hampshire. One piece I worked on was the classic apprentice panel of putting shape in, then taking the shape out of a 12"x12" 3003 aluminum panel with only the use of a English wheel. My time became limited due to the flight home, but I was able to finish the panel to Joes satisfaction.
Tonight after work in my shop, I did the same panel again. Put shape in, nice looking panel, took the shape back out. This time I developed a oil can. I find solving oil can issue one of the harder aspects of metal shaping. This skill builder is to solve the issue with the English wheel, no heat, shrinking disk, pullmax, eckold just the wheel. Due to lack of time tonight, I had to stop. My plan of attack is to find the tight area and stretch it. So the question, how do you find the area of issue?
Thank you
Bill
Bill Tromblay
Old 01-17-2018, 11:34 PM
Richard K's Avatar
Check out this thread
http://allmetalshaping.com/showthrea...ghlight=oilcan
No definitive answers to your question but a lot of comments and ideas that will assist you in thinking through the problem.
Richard K
Old 01-18-2018, 03:01 AM
Hi,
This time I developed a oil can. I find solving oil can issue one of the harder aspects of metal shaping. This skill builder is to solve the issue with the English wheel, no heat, shrinking disk, pullmax, eckold just the wheel. My plan of attack is to find the tight area and stretch it.
Thank you
Bill
Straight edge?
(Good practice on .032 2024T3)
Old 01-18-2018, 04:50 AM
KAD KAD is offline
How I would approach it.....
1. Measure crown
2. Stretch outer edge
3. Measure crown, if it's getting better repeat process.
4. If it's not getting better move the stretch in further and focus on the corners.
5. Measure crown, if it's getting better repeat process.
6. This should give an idea where the problem lies.
7. If you have no luck in an hour lightly wheel the whole sheet and start the process over.
The object is to learn from every pass where the problem or problems are located and then what every pass does to effect the issues. It's a game of knowledge....if your failing then you lack some knowledge, try not to do more than you can reverse in any single attempt.
Hint: If you didn't learn from the last thing you did then your approach is flawed reconsider a new approach.
Kirk
Old 01-18-2018, 05:03 AM
With the lowest crown wheel you've got, wheel the outer edge closest the oil can & work inwards, then back out, very gently. The edge that is closest to the oil can is tight/short & stopping the shape from being released.
I've done this with irregular shaped panels, just for fun, discs & squares are easier.
Martin
Old 01-18-2018, 08:37 AM
Hi,
Thank you
Bill
Bill
The area of issue are the edges and close to the edge
Try this.........
wheel (stretch ) all edges first ... till they are a bit wavy (not too wavy).... then..... wheel just before all of the edge BUT....make sure the the center of the lower anvil is about 10/20 mm away from the edges, that will draw the fullness out of the center of the panel, do this a few time if necessary and you will find that the oil can goes away
