clean water needed for mixing AGW flux
I always try to stress using "clean water" for mixing AGW flux.
Not tap water. Not reagent-grade double-deionized - triple distilled...... Clean spring water - bottled is fine, failing a nearby clean spring.... Here is an ad for one bottled spring water I've used, every so often out on the road: http://www.youtube.com/embed/pfxB5ut-KTs?rel=0 Pellegrino and Gerolsteiner are both very good, even with the carbonation. (pssst.... it's dissolved iron (Fe) that kills the flux dead.)
#12
Will an acetylene regulator (new) work for.the propane? WHT about hoses? Can I just buy a new regular set and keep them dedicated?
#13
Also would you prefer oxy/hydrogen for steel or stainless steel as well? What about brass or copper?
#14
Hi,
Oxy/Hydrogen is not recommended for steel or stainless as you will or could cause hydrogen enbritlment.
