Old 11-01-2009, 09:36 PM
pro70z28's Avatar
pro70z28 pro70z28 is offline
Default Stamping question?
I would like to make a Z-28 & a Camaro die to stamp 22g. steel & .32 '' aluminum.
I plan to make these on the CNC. I'm wondering would it be best to taper the edges of the logos (V-Bit) to lessen the chance of cutting the stamping metal? Or would the detail come out better if I straight cut the logos? The (1970) Z-28 is fairly simple but the camaro is script with some small details. I thought I'd use aluminum tooling plate for the die.
Hope this makes sense.
Gary Spear
Old 11-01-2009, 09:47 PM
jhnarial's Avatar
jhnarial jhnarial is offline
Hi Gary
I'm not the person to ask but I do know who I can ask.I will see if he can help you with this.
Johnny Arial
Please stay on topic.
Old 11-01-2009, 10:22 PM
All you have to do is make the male a little smaller and it will not have a 90* bend . it will look like a taper
Old 11-02-2009, 12:25 AM
Peter Miles Peter Miles is offline
Gary, if you are going to do this commercially, you might want to make sure that GM won't shut you down for infringing on their intellectual property.
Old 11-02-2009, 08:15 AM
pro70z28's Avatar
No, no commercial stamping here. Just for one lowly camaro.
Also, I should have mentioned I thought I'd try the suggestion to use rubber or similar material as the female die.
Gary Spear
