  #51
Old 11-19-2017, 04:38 AM
Dantheman84 Dantheman84 is offline
Dan,
You are getting amazing performance from your MDF on that mild steel. I also like your spot weld consistency in those corner welds, nice and even.
I imagine your parts will be in demand.
Hi Kent,
Really admire what you do so those words coming from you means alot!! Thankyou. Yes the MDF has held up for the two I've done, it's taken a beating though! At least the hammerforms are easy to make/replace.
Daniel
Perfection = Patience + Perseverance
Old 11-19-2017, 04:40 AM
Originally Posted by skintkarter View Post
Absolutely top job Dan! Very inspiring.
Thanks Richard, I've been following your build too, really high quality!
Daniel
Old 11-19-2017, 04:42 AM
Thanks all for the interest, much appreciated. I've managed to get a little more work done on the shocker/spring mounts. Will try and post some pics of them tomorrow.
Dan
Daniel
Old 11-19-2017, 07:11 PM
racer-john's Avatar
Default Spridget Rebuild
I am following along with your rebuild .
I also raced a bug-eye back in '62 that had a damaged right front corner that was supossedly fixed (not) by the local Austin dealer in Toronto.
Had the front shock up on a stack of washers with an all-thread bolt.
Woiuldn't do right hand corners worth s**t.
But still came in third in class.
John S. E
Old 11-22-2017, 09:11 PM
racer-john's Avatar
Back on post #43 you show two sets of similar panels with two and three depressions.
Can you explain please?
John S. E
