Old 05-12-2018, 11:54 AM
Default 1941 Waco UPF-7 battery box. "Its just a box"
This is battery box we had made for a customer in California. It is for a 1941 Waco UPF-7 biplane.
This is a Waco similar to the customers airplane.
The box is mounted aft of the firewall, below the floor boards. It was designed inverted and accessible from the outside of the airplane for maintenance and battery replacement. The customer brought a old corroded box, plus I have the factory drawings for the Waco. Parts that I had formed up.
The box and lid are made from .040" 5052-H32 and the structural mounts are .080" 2024-T351 aluminum. The lid and box is TIG welded together.
The cross "X" in the lid was done with a MDF form and Delrin tool in the Pullmax. Most of the tooling I make is out of Delrin, it is hard, easy machining, holds up well, easy to get and the most important for aircraft work, tool mark free.
The lid is double seamed. It was made easy with the Baileigh magnetic brake. I was skeptical at first, about an magnetic brake, but I'm a firm believer now.
Once the sub-assembly's were built, I had all the parts chromate dipped, for corrosion resistance due to possible acid from the battery. Most aircraft battery's now a days are "RG" Recumbent Gas or sealed battery's. They last longer and for the most part, don't leak.
The lid hold down studs are built from 4130 chrome moly and AN aircraft bolts, per the drawing. Once welded and fitted, they were Cadmium plated to a Boeing aircraft plating spec.
All sub-assembly's riveted together with aircraft -4 (1/8") AD rivets.
For the battery electrical connection. Waco designed there own connectors, which we re-produced in our CNC turning center. We had one sample connector and the drawings. The way it works, a post is threaded onto the battery terminals. The tulip shaped female piece is mounted to the box, insulated with phenolic washers. You set the battery on the lib and push it up into place. Easy.
It's just a box Don't you love it when someone tells you this
Thanks for looking, Bill
Bill Tromblay
Old 05-12-2018, 12:42 PM
Very nice box, Bill. Thanks for posting.
fwiw, I hear the "it's just a ....." quite often in my work.
Old 05-12-2018, 03:24 PM
dwmh dwmh is offline
Beautiful work Bill. Time well spent.
David Hamer
Old 05-12-2018, 04:18 PM
Yes, nice job, and those words “it’s just a......” are very familiar. They are normally followed with “I’d do it myself if I’d got the tools”
Gareth Davies
Old 05-12-2018, 04:35 PM
I like the rivets!
Old 05-12-2018, 07:57 PM
Bill very nice quality!
I enjoy seeing all the details
Thanks for posting
Old 05-12-2018, 08:26 PM
MP&C's Avatar
MP&C MP&C is offline
Beautiful work Bill!
Old 05-14-2018, 04:44 PM
Kevinb71 Kevinb71 is offline
Interesting method of connection. Looks like fuseholder terminals that we use. Nice work!
Kevin B
Old 05-15-2018, 02:52 PM
bimmer1980 bimmer1980 is offline
It's just a box..... yup, the words of the ignorant!
Nice work! Lot's of little details to make this box and the associated parts.
Do you have a pic of the old box?
Brad
Currently working on a new garage for the tools...
Also a member on garagejournal.com
Old 05-15-2018, 09:31 PM
Thanks, I will look for pictures of the old box.
Bill Tromblay
